How do I fix bent front seats?
kenmaraz
Hello everyone, I've got an '89 LX 5.0 5 spd, with some mods, and many more coming. But this question relates to the used '93 Cobra Black seats I just bought. The front seats are both leaning to the outside, from people leaning on the side when they get out. How can I get the seats back straight again? Should I just get the sledge out and start hitting, or is there a friendlier way? Thanks, Ken
There was recently an article in 5.0 Mustangs & Super Fords addressing this exact condition. They showed you how to correctly repair the seatback. Sorry but I don't remember which issue. Try going to their Web Site and running a search.
you have to take out the actual seat back frame and re-weld the seat back...the two pieces seprate and create the mustang "gansta lean"...also a little hammering to square up the back is good..easy fix if you can weld
Also consider the possibility the floorpan could be bent in.I had this exact problem on an '89 GT I once owned.The passenger seat was leaning over to a point,the corner of the headrest was barely an inch away from the top of where the doorframe meets the roof line.When I closed the door,the armrest would push up against the side of the seatback just a little to leave a a slight indent.
Turns out the problem was due to the floorboard having been bent upwards right near the left rear passenger seat bolt mount.When I looked under the car,It appeared the previous owner might've hit something low enough or bottemed out.The car had an Off Road H-pipe installed.The pipe had an awful low ground clearance issue.Something may've hit the H-pipe_To_Muffler flange where it bolts together wedging it into the floorboard...and yeah,right where the left rear passenger seat mount sits.I just took the seat out and used a barbell to whack the floorback down.
I have never seen the seat frames actually get bent up though.
Sorry this was long...was a suggestion i'd figure you might want to consider though.
