How do I remove whats left of the harmonic balancer?
jb1dsl
566
Marianna, Fl.
I got a 94 roller motor and the guy said that who he got it from said the crank was broke. I put it on the engine stand and began tearing it down and the harmonic balance is broke off. The crank bolt and the sleeve of the HB is still on the crank. I have to get the impact out tonight to get the bolt out but how will i get whats left of the HB off with nothing to use a puller on. These have to be pulled off with a HB puller, right? Also when i try to turn the crank it wobbles inside the block and stops, so do you think the block will be any good? I'm going to try and finish taking it apart tonight but I need to get the crank bolt and whats left of the HB off the remove the timing cover.
Thanks
