How do I set the Timing?
  • Thread starter Thread starter 22Stang
  • Start date Start date Sep 1, 2004
22Stang
26
Bay Area, CA
Sep 1, 2004
  • Sep 1, 2004
I just bought a 92 5.0 and I was wondering how to set the Timing. I have a timing light but what else do i need to do. The timing is at 6-7* I want to put it at 10*. Also do you think this would benifit my stock engine?
D
Daggar
3,902
  • Sep 1, 2004
loosen the bolt holding down your distributor. Connect the timing light to vehicle. Rotate the distributor until you've reached the desired setting. tighten the bolt. Ride on and see if it's a benefit or not. Then go to your local auto store and get a Haynes or Chilton manual for your year car.
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Sep 1, 2004
  • Sep 1, 2004
1) Pull the 'spout' connector pin (little gray square plug; about 1"x3/4") out of the wiring harness. It is located near the base of the distibutor on driver's side of it.
2) Start the car.
3) Loosen the distributor hold-down bolt (use a shallow socket with a wobbley and a 6"+ extension on a 3/8" ratchet)
4) Rotate the distributor until you achieve the desired setting (10-12*BTDC)
5) Tighten the hold-down bolt while making sure the timing is still at the desired setting.
6) Plug the spout pin back into the wiring harness.
7) Test drive to make sure you don't have engine "ping" under full throttle operation. Adjust accordingly.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Engine Brackets for Gt40 heads with ac and ps?
  • Xavierg208
  • Nov 14, 2025
Fox 5.0 Mustang Tech Nov 16, 2025
limp
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
