You'll need to create a hydraulic circuit using hoses attached to the ports on the MC that are submerged in fluid and make sure you keep the reservoir on the MC filled as well. Once you have the hoses in dunked in the fluid and the MC reservoir is full, pump the piston until no more air comes out of the hoses. Expect the level in the MC to drop significantly, so be prepared to add to it, keeping the level full enough so you don't introduce more air. After that, you should be good to go, but make sure to plug the ports on the MC when you remove the hoses, so you don't get a ton of air back into it. Some will get in, but it shouldn't be detrimental to your efforts as you're going to open the system to air anyway when you bleed the brakes. There are check valves inside the MC that won't allow air back into the MC itself, only into the ports.
