Engine How far can you go with an A9L (or other) factory computer?
reddy351
5 Year Member
Jun 13, 2006
496
Columbus, Ohio
Agreed, but I am not sure it matters.
Lets read between the lines and the picture
So none Mustang - so stand alone harness and computer.
And from his picture I would guess a Merkur XR4Ti with a 5 speed (A9L not P).
My opinion, cam will fall off before the intake does. Should have good street manners and be easy to cruise around with. Should make 300-350 at the crank (assuming electric fans). Sounds fun.
Perfection. Thank you!
96pushrod
I think they're a little easier to get off
May 15, 2018
1,478
935
123
Savannah
I would worry about the ptv clearance if using a factory piston.
For sure TW heads have clearance, inline valve heads have a good possibility of not having it.
reddy351
5 Year Member
Jun 13, 2006
496
Columbus, Ohio
According to AFR, only 1986 5.0 engines need PTV clearance checked.
Funny how a stock engine management thread has turned into an "engine building advice" thread.
96pushrod
May 15, 2018
1,478
935
123
Savannah
I guess afr is gonna help you out if you run a piston into a valve then.
You asked if a a9l can control a super basic combo, that it no doubt has done thousands of times. Of course it’ll work, but there are better options.
reddy351
5 Year Member
Jun 13, 2006
496
Columbus, Ohio
I didn't know that it had been done "thousands of times". That's why I asked. Specifically.
To be fair, I didn't ASK about "better options".
Thank you for your participation, though.
reddy351
5 Year Member
Jun 13, 2006
496
Columbus, Ohio
Those years will put flow the explode r intake by 3500 rpm
This combo will run out of cam. And then intake. And then heads.
The Enforcer 185 heads flow about 20cfm less than the "regular" cnc ported AFR 185's at every lift point. These are the "as cast" version. They're done at 6000rpm anyway. And the Exploder intake is STILL better than the stock GT intake. I think it'll be fine.
Reactions: 2 users
reddy351
5 Year Member
Jun 13, 2006
496
Columbus, Ohio
Lol,this post is a trainwreck. You sound like you already have your answers.
I guess so. Thank you for your participation. Here’s your medal.
Did you happen to notice that I asked NOTHING about if the combo would work? I asked if the A9L would be ok with the combo. Because I didn’t know. I do, now. (But everyone insists on discussing the combo, itself. :rolleyes::rolleyes:)
