87 5.0 mustang 13.48@104mph
i have a 1987 Ford Mustang Gt. aod Transmission with shift kit, 2400 stall converter, and b&M ripper shifter. i have 3:73 gears new clutches in the rearend. i have stock 5.0 block, 9mm ford racing wires, gt40 heads with ford svo 1.6 roller rockers and ford racing polished valve covers. Cobra upper and Lower intake with 1" phenolic spacer, and 19 lbs injectors. i have accufab 65mm polished throttle body and BBK cold air kit with 73mm mass air meter. i have polished aluminum under drive pullies and electric fan. autometer water temperature, differential and transmission gauges. i also have headman shortie headers 1 5"8 tube, and 2 1/2 collectors, h-pipe, flowmaster delta flow 40 series, and 3 1"2 inch tips
the question i have is i want to hit flat 12.9's with stock block, no nitrous, no blower, and no slicks, any ideas. and where can i loose weight off my car. i replaced carpet, took out heavy insulation underneath it. Put on svo fiberglass hood.
