How good is spec stage 1, mine is smelling already...
thinker
182
Corona, Ca
www.defcom5.com
I have about 1500 miles on this new clutch (spec stage 1), anyone else here have this clutch. Mine is smelling reealll bad. Whenever I drive up on my trailer or back into my driveway I can smell it. My motor is stock so I'm not doing any serious power. Is the Spec stage 2 better for me since its not organic? Also when I do burnouts in 2nd I can smell it too :( Thanks
Yeah man I had a Stage 1 for about 1500 miles, and it smelled real bad most of the time. It chattered like a son of a bitch too. But then I found out that my D&D adjustable clutch cable was frayed and causing the clutch to burn. Now I have a Stage 2 and a stock clutch cable (non-adjustable) and this setup is 100x better. What cable and quadrant are you running?
youre frying the clutch dude and wearing out the TO bearing. Give the cable some slack, then go under the car and pull on the cable where it meets the plate, it should be loose when the clutch pedal is up... Hope this helps.
Over 10K on my SPEC stage 1, still like the day I put it in. Never chattered even once, never smelled, easy pedal and smooth operation and lightswitch grab when it's hot. I love it, I'd do it again in a heartbeat. UPR triple hook quadrant, Extreme FWA, and FRPP adjustable cable. Never any problems with any of it.
