How hard is it to rebuild a T5?
sunil6784
620
Boston, MA
How hard is it to rebuild a T5? My 5th gear synchro is shot, and I'm thinking of tackling it myself. I'm gonna get the video thats supposed to show how to do it...
http://cartapes.com/templates/frmTemplateR.asp?CatalogID=148&SearchYN=N&subFolderID=20
Are there any special tools that are needed? I've never pulled the tranny out before, but I'm thinking that will be my winter project along with a clutch job. I'd like to order the master rebuild kit and do it all at once so I don't have to worry about the other gears/synchros either. Has anyone done one for the first time, and if so, how difficult/complicated was it?
I just pulled out my T-5, its something you can definitally do in a day. Not the rebuilding part though.
I rebuilt mine with a sledge hammer.
In favor for a TKO 600.
I rebuilt mine with a buddy. Im only 17 and have only had experience working on bikes, rebuilding cassette hubs and whatnot, and doing minor stuff on the mustang. We rebuilt the tranny, took about 2 hours to pull it, 8 hours to rebuild it (put it together a few times wrong then disassembled and reassembled probably 5 times) and finally got it right. Just when your all done make sure only one gear is engaged at any given time and you have a neutral, so you dont blow it up when you put it back in. Id recommend the kit from the user brenspeed on ebay, its a motive gear kit and its cheap as far as rebuild kits go. Its got timken bearings and the tremec manual to boot. Good luck, you can do it.
I bought the tape and it shows you every step involved...I have done 3 so far and they have all been great afterwards....
The only tool i had to buy was a dial indicator.
A press is needed also.
i pulled my tranny in about 2 hours by myself (after having done it twice in the past week), me and my dad rebuilt the thing in a sunday (probably about 6 hours), and now it works great
about the press.... we just used a chisel and hammer and kept hitting it on opposite sides, being careful not to damage any machined surfaces.... and to remove pressed on gears and what not, we banged the shafts against the concrete until they fell off haha... of course we had a different shaft we were using for assembly
make sure you have lots of room to work and lay everything out exactly as it came out so that you dont miss a part when it comes time to put it back together
...and use assembly lube on everything
good luck and keep us posted eh
