Tonight I'l gonna try putting my ps pulley in the oven to heat it up and then put it on. What temp level and how long should I bake it for?
Dave
Dave
S/CBlack95GT said:I put mine in the oven at 350 for like 10 minutes. I then applied RTV sealer in the keyway and oil on the outside of the hub. Dont go too hot or you may burn the front main seal.
With the right installer its goes on...just pretty tough. But heat wont hurt i dont think
nmcgrawj said:Power steering pump....not balancer![]()
Mine was a PITA to put back on...convinced me never to take it back offWith the right installer its goes on...just pretty tough. But heat wont hurt i dont think
mootang said:if the heat doesn't work you need this tool!
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DW87021&N=115&autoview=sku
FORCED2DV8 said:I put my pump in the freezer and i boiled water with the pulley in it, put lube on the shaft and they slid together like a porno movie.
must have worked real good
