How long and hard is it to replace side mirrors?
I can go on "all-data" at my school tomorrow and post you up some directions. But im sure its not hard to figure out on your own. Probably just pop off the tweater, to reveal some screws. Undo the screws, disconnecte the wiring harness to the power operated mirrors, install the new mirrors, reconnect the wiring harness, pop the tweater back on.
I'm sure its that simple. But if i remember, i'll look it up tomorrow for you at tech school.
UDTBadkarma said:
I can go on "all-data" at my school tomorrow and post you up some directions. But im sure its not hard to figure out on your own. Probably just pop off the tweater, to reveal some screws. Undo the screws, disconnect the wiring harness to the power operated mirrors, install the new mirrors, reconnect the wiring harness, pop the tweater back on.
Yeah, that's about it. Take the cover off of the tweeter. It'll just pull off, but sometimes the glue that holds the cloth on gets stuck to the plastic that holds the cover on. May take a little tugging.
Then undo the screw that's in the hole and pull the tweeter housing out.
Then unhook the wiring harness (May or may not have to remove the door panel. I can't remember right off.) and remove the three bolts that hold the mirror to the door. The mirror should just pull off.
I think the cobra mirror goes back on the same way, but I'm not positive.
