How long does your 4.6 take to warm up?
Jbauer
506
Is it all V8s that take a while to warm up or something?
My moms car warms up in like 2 minutes of driving, my friends focus is crazy, his warms up like 15 seconds of driving..
My car.. it takes like 3 miles till it even moves from C. Even when i drive my car to the track, at like 100 degree weather, my temp is still slightly below half. at the absolute hottest, it may get to a little tad bit below half.
I was going to go to napa and get one of their 'superstats', i think my car may be over cooling. The car has almost 90k miles, and when i got it about a year ago the coolant was pretty nasty, so i'm not sure if the thermostat has ever been changed.
Do you mean for the needle to be pointing in the middle? I dunno, about 5-10 mins of driving...even in the summer.
The heat works right away though. It could be 20 degrees outside, if i start driving and then turn the heat on about 5 blocks from home, it will already be blowing slightly warm
Takes a long time for mine also.
On a summer night when I am usually leaving work it will be 6-7 miles before its warmed up.
Heat does come on quick though, even in winter.
Would it have anything to do with the thermostat? For example one car has a 140 thermostat compared to another one having a 180?
Besdies most of these gauges are dummy gauges and don't give anywhere near an exact reading, more like an on/off as I recall.
No. The stock tstat is 192 degrees and thae coolant won't begin to circulate until the tstat opens.
The reason why the engine takes so long is because aluminum headed engines tend to take longer to warm up then iron headed engines. The AL acts like a big heat sink absorbing most of the heat in the first few minutes.
It doesn't mean anything is wrong with the car. It's just simple physics
Right, but the thermostats primary function is to prevent the car from over cooling itself. The car to me anyway, seems to run really cool.
too late for a return now anyway
