How many quart of oil is T-45 and rear diff ?
From 2000 Model year Ford service manual:
7.5 Inch Rear Axle 1.5 L (3.5 pints) [1]
8.8 Inch Rear Axle (Base & GT) 1.0 L (4.0/3.75 pints) [1]
8.8 Inch Rear Axle (Cobra) 1.4 L (2.9/3.10 pints) [1]
Traction Lok Friction Modifier 4 oz.
[1] -- Service refill capacities are determined by filling the axle 6.3-14.3 mm (0.25-0.57 inch) below the bottom of the filler hole. The vehicle must be on a level surface
From 2000 T-45 model year: Manual Transmission Fluid Capacity 3.1L
Can you translate those in 'quart' pls :D , i dont know wtf is L and Pints is :rlaugh:
The GT 8.8 solid diff uses 3.75 to 4.0 pints (75W90 for 2001 and older, 75W140 for 2002+). That's almost two quart bottles. Will have some left over (more if adding friction modifier). Remember it is not fill until it runs out.
Buy 4 quarts of Mecron V (or what ever manual transmission fluid you want) for the T45 manual transmission.
Have you tried to buy a quart of Mecron IV or Dexron III lately? Both have been discontinued.
Ford TSB 06-26-1 authorizes Mecron V to be used in applications formally calling for Mecron IV.
