How many quarts/Tranny fluid change?
I already checked the archives-nothing....
Guys,
To tell me-No one changes there tranny fluid??? come ooooooooooooooooooooon. i already checked the archives, and there is only 1 post regarding tranny fluid changes, and its for a 5 speed. can someone help a bro out!
Thanks in advance.
Anthony :flag:
No, I dont change it unless it has very low miles on it or I know its history. If you have an auto trans at 100,000 mi. and its working fine, a fluid change can damage it. If you dont drain the torque converter too, you will only change about 1/2 of the fluid. If you know its been changed every 24,000mi, I would keep changing it at those intervals.
If you insist on changing it, check it now when its hot to insure that it is full. Then drain it and measure what you took out. That will be a good amount to put back in. You will prolly get around 6 qts out of it if you dont drain the converter(some of them have drain plugs and some dont). You will have to remove the dust cover and turn the engine slowly to look for one. My book doesnt say what the capacity is, it may vary. I am guessing 12-14 qts total. Try calling the auto parts store, they can usually tell you what it takes. When you fill it up, you should go slow with the last few qts and check the dipstick with the tranny hot and engine running in park. And if you change it make sure to get a new filter too. This can be a very messy job if there is no drain plug in the pan. Be prepared for fluid to go everywhere, that will make it hard to measure what you took out. I always have more fluid on hand than I think I will need.
Here's what I remember from installing a B&M shift kit several years ago....the instructions that came with the shift kit said 8 quarts, but the tranny ran very funny after doing this install and a few days later found out that it should have been 12 quarts (I just kept adding until it read full)...my AOD died a few months later at which point a tremec took it's place....sometimes the instruction lie.
Thanks for the help-JERRY!
Hey man,
Yep-I have a drainplug-so thats cool, and I have changed the filter and fluid since i got the car with 85,000 miles on it. and yup-Its an AOD. i now have 95,000-But i have 4.10's which gives the incorrect mileage.
My goal is to change the fluid so often, As to get totally new fluid in the tranny without having a professional flush. I have a Trans-Go shift kit and cooler w/a B&M T-handle shifter-She shifts perfectly, No prob's whatsoever! I was just curious-What the Quart capacity would be for just a regular change. Thanks-4-Ur help.
Anthony :flag:
Don't want to steal his thread...but I have the same question for a stock T5. How much fluid does it need? I know some will say "until it starts to drip out of the fill plug" but I need to make sure I have enough fluid purchased prior to doing this (and I will be filling via removing the shifter since I have no means of getting fluid up to the cramped area around the fill plug.
So yeah, how much fluid for a T5?
Thanks!
Thanks!
You dont need to remove your shifter. You can buy a simple squeeze bottle with a hose from the auto parts store and simply squirt the fluid into the top hole till it starts to pour out. They are only about $5 and easier than removing the shifter.
