How much does a T5 weigh?
  • Thread starter Thread starter TrophyHead
  • Start date Start date Feb 28, 2004
TrophyHead
1,195
11
49
PA
Feb 28, 2004
  • Feb 28, 2004
I'm helping a friend take a T5 off his car on Sunday. Does anybody know how much a T5 weighs? I've searched and can't find anything. I know a AOD is 60 pounds heavier but thats it. Is a tranny jack needed with a T5? Im thinking No cause it looks kinda small.
Also we have everything off the car except the bellhousing bolts. Just take the bolts off and just slide the tranny off the spline should I be really careful here or is that spline pretty heavy-duty and wont break/bend. First tranny job.
Thanks for any info you have.
StreetStang37
451
San Jose, CA
Feb 28, 2004
  • Feb 28, 2004
i think its like 50-60lbs. I got a couple C-4's in the garage and they weigh something like 70lbs. but I think the T5 is lighter.
bmorrisj
449
Buena Park, CA
Feb 28, 2004
  • Feb 28, 2004
with fluid a t-5 weighs about 100lbs...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 28, 2004
  • Feb 28, 2004
See http://www.ttcautomotive.com/English/products/T-5.asp#Car for specs. The weight is 75 lbs dry according to the website.
drgn5.0
603
  • Feb 28, 2004
T5's are about 80 lbs.
SPEED FREAK
1,448
Regina, SK.
Feb 28, 2004
  • Feb 28, 2004
I never use a tranny jack to install one... Mind you I have a hoist or 13 to work with so I dont know what it would be like doing one on the ground...
blk92stangg
583
Hawaii
Feb 29, 2004
  • Feb 29, 2004
I just did a AOD to T5 conversion, and I would swear the AOD is twice the weight of the T5. Not sure of the exact weight, but if you have only 2 guys I would use a floor jack to keep the tranny level while you wiggle it loose. BTW, did the whole conversion on the ground and it was a PITA. Glad I did it tho.
DemonGT
871
51
49
Sparta,WI
Feb 29, 2004
  • Feb 29, 2004
tranny jack? i removed my T5 by myself with no jack..just unbolted it and slid it out onto my chest and rolled out from under the car...would need two ppl to put on in though..one to lift it up and hold it one to put bolts in...
TrophyHead
1,195
11
49
PA
Feb 29, 2004
  • Feb 29, 2004
Thanks for the advice guys got it down today didnt realize how light they were.
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
20K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
