How Much Does Exhaust System Cost?
  • Sponsors(?)
fiveohwblow
Official Member
Jul 21, 2005
2,169
140
135
I would suggest a pacesetter y pipe which will convert to true dual. This will run you about $150. Then I suggest buying an inexpensive cat back, even an oem takeoff since your sixer will sound like ass to anyone within earshot if you choose a louder exhaust. Then take it to an exhaust shop if you can't install it. I'm guessing around $450 for all that.
xsw4gx17
11
i went to a auto shop and they told me 900 dollars.. for flowmasters and make my y pipe dual or something
900 dollars is way to much for this
'66 coupe
1,202
9
39
Lakeland, Fl.
www.sounddomain.com
What I did on my old '01 was buy a GT take-off catback(these were still plentiful in 2003), then I bought 2 MAC Flowpath mufflers to replace the OEM ones. I had an exahust shop made an H-pipe to connect it all after the cats, and weld it all together. After parts, shipping, and install I was in about $430.
If I did it again, I'd just get this: http://www.americanmuscle.com/99-04...um=Shopping&AMID=99-04-v6-mac-catback-2000-V6
You can install it in your driveway on ramps and jackstands. And if you decide to go True Duals later, you can simply have a shop cut the y-pipes out and fabricate and weld in a new mid-pipe. I wouldn't worry about it being True duals unless you plan on doing some extensive mods to your engine that are going to greatly increase the amount of exhaust coming out.
As for sticking with OEM mufflers because the V6 "sounds like ass." That's relative from person to person. I've heard good sounding V6es with MAC and Flowmaster mufflers, and I've heard crappy V6es with cherry bombs or fart can mufflers. I've also heard some pretty crappy 2v 4.6 v8's with aftermarket exhaust. The only crappy 3v 4.6 I've heard had Pypes mufflers and sounded like raspy ass. Point being, you kinda have to match the muffler to the motor.
I'd go for something mellow, but not just outright LOUD, like the MAC Flowpaths; they won't be raspy with the V6.
Bullitt347
man bewbs please...
Mar 23, 2007
2,199
1,006
184
Pacific NW
I installed a Magnaflow kit on my 01' V-6 and it sounds good. I modified it so it would fit the GT rear valance as the Magnaflow dual kit for the V-6 assumes you have a stock rear valance. the Magnaflow kit was about $495.00 if I remember correctly.
Thread starter Similar threads Forum Replies Date
U How much HP does and exhaust add? SN95 4.6L Mustang Tech 9
T-Sho Roush How much horsepower does a Roush Side Exhaust system take away??? Special Production 2
Habu135 Fox : How Much Power Does a Stock 1993 Cobra Make? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
T Need good/affordable cooling fan for Mach 1 that does not vibrate too much 1996 - 2004 SN95 Mustang -General/Talk- 3
8 Fox How Much Does A 89 Lx Htchback Weight From Factory 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
C How Much Hp Does This Fox Have? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
8 How Much Does A 28oz Weight For A Flywheel Actually Weigh? Fox 5.0 Mustang Tech 6
toxzzic1 How Much Hp Does A New Throttle Body And Plenum Help??? 1996 - 2004 SN95 Mustang -General/Talk- 11
stangboy How Much Does Your Notch Weigh 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
99FiveOh Electrical How Much Power Does The Stock Ignition Have? 1994 - 1995 Specific Tech 1
Edster How much power does an H pipe really make? Classic Mustang Specific Tech 6
9 how much horsepower does my 95 gt have? 1994 - 1995 Specific Tech 1
Galaxius How much of a difference does a tune make? 2005 - 2014 Specific V6 Tech 5
Reimann How much does a 60,000 mile tune up cost for a 2004 Mach 1? SN95 4.6L Mustang Tech 11
sneaky98gt How Much HP Does it Take to Trap 113? 1996 - 2004 SN95 Mustang -General/Talk- 16
whitehorse1 Headers..how much difference does brand make? 1996 - 2004 SN95 Mustang -General/Talk- 17
C How much does ethanol gas effect your tunes? 2005 - 2009 Specific Tech 3
1 How much does the 05-09 GT Grille with foglights weigh? 2005 - 2009 Specific Tech 4
sneaky98gt How Much Power Does it Make 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
patman0911 The "How much oil does my 4.6L take?" debate settled once and for all, finally! 1996 - 2004 SN95 Mustang -General/Talk- 7
Sixty7Restomod Why does it cost so friggin much to install a headliner? 1965 - 1973 Classic Mustangs -General/Talk- 15
G How much does yours move? SN95 4.6L Mustang Tech 24
D How much does these go for? Saleen 1996 - 2004 SN95 Mustang -General/Talk- 8
Back2Mustangs How much does Mach460 system weigh? 1996 - 2004 SN95 Mustang -General/Talk- 5
SadbutTrue How much meat does the Weiand Stealth have to it (need to grind for distributor fit)? Classic Mustang Specific Tech 13
8 How much timing does gt40p heads like ! Fox 5.0 Mustang Tech 1
8 How much oil does a 2.3 take? 2.3L (N/A & Turbo) Tech 12
Pokageek How much does siding cost for an average home with outside coverage(guessing 3500sqf? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
N How much power does it take? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 22
8 how much does my notch weigh? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
hungrymonkey FI does not give much warning when you run out of gas... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 33
gnx547 About how much does it cost to get a hood painted for a fox body? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
fivespeedsteed help with draining oil. what plug does how much? Fox 5.0 Mustang Tech 4
stangman356 How much power does a hypertech tuner add 1996 - 2004 SN95 Mustang -General/Talk- 5
C How much does it cost to get a set of pistons fly cut? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
MI95Cobra how much does it cost to rebuild a t5 transmission??? 1994 - 1995 Specific Tech 5
G Why does my LX lose so much oil? Fox 5.0 Mustang Tech 9
B How much does it cost you to prep a block? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
T How much does the V6 Mustang weigh? 2005 - 2014 Specific V6 Tech 11
97gtconv. How much does your Stang weigh? 1996 - 2004 SN95 Mustang -General/Talk- 28
5spd GT Quick, how much does a air bag sensor cost roughly? 1996 - 2004 SN95 Mustang -General/Talk- 3
M How much does a Procharger bracket for '94 GT cost 1994 - 1995 Specific Tech 1
Joey5.0 How Much Hp/Tq Does My Combo Have? Fox 5.0 Mustang Tech 37
OrangeMustangGt my car got hit....how much does a saleen bumper cost? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
I How much does being BORED add to cu in? SN95 4.6L Mustang Tech 11
LUCAFU1 How much Peel Away does it take to do a whole car? Classic Mustang Specific Tech 7
The Green GT How much does a leather rear seat go for? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
Nvidia WTF does my gas mileage suck so much? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
1 how much hp does..... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
mustangkid05 how much hp does every gt come stock with? 1996 - 2004 SN95 Mustang -General/Talk- 33
