how much fluid in an 8.8 rearend?
  • Thread starter Thread starter keith black
  • Start date Start date May 2, 2004
First Prev 2 of 2
HISSIN50
34
129
May 4, 2004
#21
  • May 4, 2004
  • #21
it is a somewhat common practice to not use the modifier, as well as using fluid for an open diff (non LSD) to help clutches stay locked up, at the expense of needing to rebuild them more often.
M
mbl585
139
#22
  • May 5, 2004
  • #22
Ok, so here is my REAL questions for you experts....will replacing diff fluid with a synthetic improve performance or do anything benefitial to you system versus just keeping the same fluid in there that was put when a gear swap was done years ago.?
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
May 5, 2004
#23
  • May 5, 2004
  • #23
IMO, After the initial period of 'breaking-in' the gears, I would have changed the fluid. All the same advantages to running synthetic oils in your engine or transmission apply here. You may not get in the car and go "Wow!" - but there is a difference.
HISSIN50
34
129
May 5, 2004
#24
  • May 5, 2004
  • #24
i have read differing opinions on the syn vs conventional rear end fluid..... i think the concern with syn being that it is too slick. i would however, run a syn in the pumpkin. they are made to be run in there.
one big advantage: many synthetic 85-140's will flow into the bearings much sooner than a conventional 80-90. so one gets much better protection, as well as better flowing at cold temps. as i recall, it can take conventional 80-90 quite a bit of time to get into bearings.
i now switch all the cars over to syn's. it costs a little more money, sure. but one can pretty much fill it and not worry about needing to change the fluid (for service interval reasons). nice peace of mind.
good luck.
First Prev 2 of 2
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
R
Interior and Upholstery How to remove seatbelt torx screw
  • Riley Barth
  • Jul 6, 2026
Fox 5.0 Mustang Tech Jul 13, 2026
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
