I've seen cams for 5-600, how much will it cost to get them installed, or how hard is it to install them yourself? Do you have to remove the engine?
johnnyvista said:comp cams 2v cams: about $570
comp valve springs $250
labor/installation: $560
total: $1380
to replace the cams, they have to pull the engine, take the heads off, disassemble them, and reassemble them with the new cams, then put the whole engine back together.
myponyrocks said:I think Johny got ripped off
Did they change your headlight fluid too?![]()
However, I am not looking forward to the day that I flush the cooling system and have to remove the radiator, water pump, hoses, etc. I'll probably take it to a shop for that.
