how much hp can a stock block hold?550?
dannydoo
195
im inches away from pulling my motor and putting forged pistons and rods...but if this block cant handle 475 or upwards im gonna scrap it..
and have fun in the process with 26psi of boost ... theres always an option of those support sleeves that strenghten the combustion chambers too right?is that expensive?
i only want 500rwhp for starters..
the reason for the forged is i want to seal the headgaskets tight and not worry about the the rings and rods and pistons..
that will that crank hold up w/good studs?
it all comes down to how often your going to be in boost . my car has been together for 3 years with a stock bottom end and it sees 10 lb to 15 lbs every time i drive it on the weekends i have only had one blown head gasket and that was my dist fault . i f you are shooting for more than 475 at the wheels you will need a new block .i would bolt the t-trim on and see how it works out then go from there.
The block can go 9's and has been proven, but how long and who tunes it is another story.
We have guys running mid 10's with a stock hypertectic piston block, others feel the need to swap pistons, others dont.
But my question to you is... WHAT makes you want to go 26lbs of boost?
That seems rediculous for no reason.
Swapping pistons have nothing to do with head gasket sealing. The rods and crank are pretty stout believe it or not, the main problem is the hyper junk pistons that may fail at any given point. This can be remedied easily with a set of forged pistons and gapless pistons for a tight seal.
The BLOCK will split before the internals go(most likely, if the tune is right on and you keep your RPM's conservative)
guys chill out! i didnt say i want 26psi all the time....i meant i would like to beat the engine to death w/26psi if im going to have to swap my block..
im figuring on 10-15psi of boost and using it cautiously.
the thing is when i start a project,i quickly get posessed into going extreme.
if i swap my pistons to forged i ll be happy..
i also heard lowering the compression will help u to revv higher is that true??????????and could be done by adding a ticker gasket or doublestack
my post was how much hp untill the block gives out?in case i do go extreme posessed??? causei dont want to do all that work into a poor block...
thanx
My good friend has a 540rwhp Fox running 8 psi on the stock block. He's been running it for 3 months now without problems and revs it to 7000rpm at the strip. He's got a Dart block waiting at home for him though. I think he has a rare case, most people don't recomend going over 500rwhp.
there is a company advertising in this months mmff that has produced 685rwhp (787 fly wheel horse power) with a stock block. but they have a steel main support girdle, and a lifter valley support girdle. their web site dosent work yet so you will have to get the new issue of mmff
Lowering compression will not do ANYTHING with the REV limits.
Dropping compression will let you "safely" run more boost with pump gas.
Dont believe everything you read. I suggest you seriously start reading up and doing research before jumping into anything, people tend to say something that will end up costing someone money.
Most likely the stock internals will hold up longer than the block will.
Some make it through 600rwhp with no problem, others arent so lucky.
i've heard the stock block can handle up to 600 flywheel hp. anything over that is on borrowed time. If you want 500 rwhp, i would make sure that you have the main supports girdled and forged pistons. the internals will go long after the block cracks. the stock pistons, in most cases, are crap. if your running boost, low compression IS A MUST! if you want to see 15 psi, keep the compression down to at least 8.5:1.
