How much is it worth?
  • Thread starter Thread starter LXSTASY
  • Start date Start date Apr 15, 2005
LXSTASY
932
Long Island, NY
Apr 15, 2005
  • Apr 15, 2005
How much HP would be given up by using the stock cam with 1.7rr as opposed to a semi-mild comp cams, lunati or aftermarket?
the combo as of right now is afr 165's and a ported cobra intake with supporting mods.
Any ideas?
Dan
vristang
4,933
101
124
Seattle
Apr 15, 2005
  • Apr 15, 2005
Don't know.
Since I don't have a dyno the only way to compare the 2 is by actual valve lift and duration.
What are the specs you are considering?
How do they compare to the stock grind?
I don't remember the specs on the stock cam.
5.0fox
410
buckley/enumclaw wa
Apr 15, 2005
  • Apr 15, 2005
well the reduced friction should be worth up to 10 horsepower, but i have no idea what the increased lift will add.
darthcual
985
Arlington, TX
Apr 15, 2005
  • Apr 15, 2005
The increased lift will help you at the top end of the rpms when you can hold the throttle down slightly longer, how much hp all depends on your other mods.
LXSTASY
932
Long Island, NY
Apr 20, 2005
  • Apr 20, 2005
Well my other mods would be AFR 165's, ported cobra intake and supporting hardware running the stock cam and 1.7 rr's.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 20, 2005
  • Apr 20, 2005
Your giving up 20-35hp depending on the cam. Don't be cheap, Dan Think about all those ***gots in our area who's mommy and daddy bought them 03 cobra's or BMW's. Wanna beat them or stay behind them?
LXSTASY
932
Long Island, NY
Apr 24, 2005
  • Apr 24, 2005
You can still make decent power with the stock cam and have perfect driveability.
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
Engine adjust roller rockers on new 393
  • maxine-70
  • Dec 27, 2023
3K
Fox 5.0 Mustang Tech Dec 30, 2023
AeroCoupe
