load71 said:just like the title says. how much power can a stock 5.0 aod tranny handle? I do not want to convert to manual, and i do not want to go a C-4 because i do a lot of high way travel so i can not afford to lose overdrive. Thanks in advance.
ponycar17 said:From what I hear, OD will be the first to go... Try NOT to race in OD, and don't do the 1-D-1 shuffle, and the tranny will be fine for a long time...
It looks like you're basically stock on the motor end though, so what's the issue?...
i read somewhere that 1-d-1 shuffle is true but if you must race do the D-wait for 2 then switch back to -1 then -D then -OD i have had no problemsponycar17 said:From what I hear, OD will be the first to go... Try NOT to race in OD, and don't do the 1-D-1 shuffle, and the tranny will be fine for a long time...
