One other Question is does the Saleen kit come with a intergrated boost bypass valve.
Below is a list of parts included with the Tillman Speed kit and the Brenspeed kits.
Tillman Speed E-Force kit:
Tuning Tillman Speed's Exclusive SCT X3 Powerflash w/Custom Tunes
Supercharger/Intake Assembly w/15" Runners
Air Inlet With 85mm Electronic Throttle Body
41# Bosch Fuel Injectors (set of 8)
Air-to-Water Intercooler
Colder Spark Plugs (HT0)
Steel Belt Tensioner Brace
Competition Air Intake Assembly (+15RWHP!)
GT500 Dual In-Tank Fuel System
7PSI Supercharger Pulley
All Hardware and Complete Detailed Installation Instructions
Truly a FULL Supercharger System out of the box!
Brenspeed Stage 2 and Stage 3 kits:
Our turn key Saleen Stage 2 supercharger package is a complete kit that includes everything you need to support 485+ flywheel horsepower. You get the high quality Saleen twin screw supercharger producing 6.5 psi of boost (boost varies based off of RPM and altitude), 3.6 pulley and belt, a Steeda cold air intake, 39 lb. injectors, Vacuum line kit that improves fuel system efficiency, and a custom Brenspeed tuned SCT X3 programmer. This package produces an amazing performance improvement in a compact supercharger package. Although rated at 485 HP many Brenspeed customers have made over 500 HP/430+ rwhp on a stock car with this package on 93 octane fuel.
Our turn key Saleen Stage 3 supercharger package is a complete kit that includes everything you need to make 500 flywheel horsepower. You get the high quality Saleen twin screw supercharger producing 9.5 psi of boost (boost varies based off of RPM and altitude), 3.4 pulley and belt, a Steeda cold air intake, 39 lb. injectors, Kenne Bell Boost-A-Pump, Vacuum line kit that improves fuel system efficiency, HT0 spark plugs, and a custom Brenspeed tuned SCT X3 programmer. This package produces an amazing performance improvement in a compact supercharger package. Although rated at 500 HP many Brenspeed customers have made over 520 HP on a stock car running 93 octane fuel.
