how much should my full weight 95 convertable gt weight?
I do not know where you guys get these numbers at!?!? I have weighed my car a minimum of 20 times and the LIGHTEST I ever had the car was 3510 without me, or 3670lbs with. When I still had the stock heads it weighed 3803lbs with me in it at Englishtown. I could only hope to be in the 3500lb range with driver.
I would have to suggest that KC scale is way off or something is wrong considering the rest of us come is at the same weight. Here are 2 links to back up my point. 3450 curb weight.
http://www.edmunds.com/used/1994/ford/mustang/11014/specs.html
http://www.intellichoice.com/reports/vehicleReport/vehicle_nmb/100011819/section/all
Definition:
Gross vehicle weight rating" means the weight specified by the manufacturer as the loaded weight of a single vehicle. this estimate of how much the vehicle weighs when loaded with passengers and cargo.
curb weight=unloaded weight
No, the scale I use is inspected annually as it is my uncle's scale that is used for his stone/cemement business and it HAS to be accurate. Also, I have a body kit which stangfreak has verified weighed 45-50lbs when he took his off, along with a chrome roll bar that EASILY weighs 60+lbs.
