I was changing my trans fluid in the T-3650, I had it put on ramps in the front and on the ground in the back. I put over 3.5 quarts but less than 3.8 quarts when it started running back out. I know the book says 3.2 quarts. I was thinking 4 quarts. I can't seem to get to the trann. with it on the ground to check it while it is level. Is this to much fluid. Thanks
I was able to get level, and I drained it down the the fill hole stopped dripping
but not the other 1/2" below the fill hole. Maybe I'll try something esle. I think this the level that the site is talking about on change to Royal Purple to fix there problem.
