how reliable are 347's?
fivespeedsteed
Oct 17, 2003
748
22
69
Richmond, VA
just as much as 302's, 306's, and 331's? ive heard of the oil starvation from the cylinder walls, but they came out with stuff to fix that, so is a small block stroked that much any less reliable than a 306? i know people that boost go with shorter strokes, is that just to keep down on how much things are moving, or some reason? im just curious...
from what i've gathered, a 347 has more piston "rocking" (however it's phrased). when the piston is at the bottom of the cylinder, the extra stroke pulls the piston skirts out of the cylinder bore more causing it to rock a little bit when the crank rotates fully then starts on it's compression stroke. big bore 347s are the way to do a 347.
First, I'll talk about my thoughts and then give you some facts below:nice:
If you want to have block security, assuming you are wanting to drive a 400rwhp stroker as a daily driver, I would suggest upgrading a B50 Sportsman block (guys have gone in the high 120-low 130 mph marks with that block) or a Dart Block which is much stronger even than the B50. The B50 block is $1000 and the Dart is $1900.
Remember there is a difference between a daily driven car and a street car.
They can be made reliable if you have a good builder:nice: This is further explained below.
I have a couple friends with 347 cubic inches and a couple with 331 cubic inches. Both are nice in their own ways:nice:
A few days ago over on the corral, there was a racer that couldn't get his 347 with a 5.400" rod to prevent blow-by. He had it at a couple reputable shops to rebuild it. Oil ring problem or other? I'll let you decide...
Stroker Info
http://www.strokerengine.com/RodStroke.html
http://www.fordmuscle.com/archives/2003/09/stroker/
http://www.mustangandfords.com/techarticles/5197_331ci_stroker_engine/
Piston diagrams:
http://www.ariaspistons.com/pistondiagram.html
The 3.25" stroke (331) and 3.4" stroke (347) both make similar power numbers.
The 3.4" (347) stroke DOES have a steeper rod ratio.
A stock 5.0L displacement is 302 cubic inches. It consists of a 3.00” stroke and 4.00” bore. The stock rod is 5.090”.
A 306 is created by reusing the stock 3.0” stroke but boring/honing the cylinder walls .030” to create a 4.030” bore. It utilizes an oversized piston, larger than the stock 4.00” stock bore/piston. A 306 is a form of a budget build and is not intended to make extra power, but to create fresh cylinder walls for longer engine life and revive lost compression through high mileage engines.
Both the 302 and 306 reuse stock 3.00” stroke crank and stock 5.090” rods. The 306 needs new oversized pistons.
A 331 cubic inch engine (stroked 302), consists of a new crank of 3.25” of throw, and the 4.030” overbore that creates fresh cylinder walls. To get the 331, you need a crank, of 3.25”, new rods of 5.315” or 5.4” length, and a .030” overbore from stock bore.
A 347 consists of a 3.4” stroke, 5.315” or 5.4” rod, and oversized pistons of 4.030”.
The vast majority of 347s and an occassional 331 need extra cylinder skirt block clearance at the cylinder walls to clear the rod bolts as a crank rotation is being made. The throw of the crank is too large to have safe tolerances to rotate.
Piston speed in feet per minute:
A 302 with the 3.00” stroke moves 3,000 feet per minute.
A 331 with the 3.25” stroke moves 3,250 feet per minute.
A 347 with the 3.40” stroke moves 3,400 feet per minute.
Faster piston speed equals faster wear and the need for a bit stronger components as the fpm increase.
Excellent Unbiased Information Below:
If you want to read about how steep rod ratios affect performance...read this:
If you are going to build a true street car (daily driver), get the 5.315" rod. The only real advantage the 5.4" rod has is it's longer dwelling time (very slightly different which is irrelevant) at BDC/TDC which gives those drag racer/track kings that very slight edge over the next guy.
The offset wrist pin the 5.315" rod makes that rod act like a 5.415" rod anyways (.100 difference) without the oil ring/wrist pin intersection.
Mark O' Neal at CHP/Probe recommends it for street engines.
Daily Driver = 5.315" rod – 1.175” Compression Height
Track Car = 5.4" rod –1.090” Compression Height
5.400" Rod 347 vs. 5.315" Rod 347
Left is a piston with the wrist pin intersecting the oil ring land; 5.4" rod piston.
Right is a piston where the wrist pin does not intersect the oil ring land; 5.315" rod piston.
The additional leverage applied to the cylinder wall (thrust) side of the shorter 1.090 compression height piston combo makes it even more important to properly bore, hone, and ring gaps to ensure any type of longevity. The longer 1.175 compression height piston combo is more forgiving by allowing more room for error, because of the longer skirt and pin location. It also provides better oil control.
The use of a good dimpled oil support rail (needed for 1.090" pistons) that can't rotate in the groove (due to the dimple facing down into the pin bore and effectively locking it in place), you can help combat "extra" problems with oil consumption. Bad ones, use what amounts to a 3rd oil ring wiper with no dimple that clamps against the back of the oil ring groove and they can rotate and/or roll in place. A good builder and parts used are key. Here is a picture of an oil ring support in an aftermarket ls1 stroker piston, which helps put text to visualization:
http://www.gmhightechperformance.com/tech/0608htp_ls1_engine_build/photo_58.html
The oil ring support goes underneath the oil control expander on the very bottom, if looking at the piston from it's 'in engine' orientation. The oil support rings go directly above and below the oil control expander, with the oil ring support on the furthest wrist pin side.
The 5.4” rod piston has a shorter skirt, which causes it to be a bit more unstable from top to bottom.
5.4” (1.090” piston) combo is sometimes considered lighter than a shorter rod – 5.315” rod with 1.175” CH.
Probe’s lightweight 4340’s are 510 grams for the 5.090” rod, 520 grams for the 5.315” rod, and 530 grams for the 5.4” rod.
The ultra light 4340’s are 531 grams for the 5.4” rod, 530 grams for the 5.315” rod, and 518 grams for the 5.090” rod.
The 5.4” rod and 4.030” with the 3.4” stroke’s piston weighs 474 grams.
The 5.315” rod and 4.030” with the 3.4” stroke’s piston weighs 474 grams.
Using this example, the piston/rod combo, whether using a 5.315” rod or a 5.4” rod, the rotating weight is virtually the same. If not the lighter side, going to the 5.315” rod in this example.
The weights are approximate and could very well go the other way.
If long engine life and reliability are your goal (daily driver), keep the piston pin out of the ring area, by utilizing the 5.315” rod and 1.175” compression height piston. Having the piston pin close to the hot piston crown is just asking for premature engine blow-by or even failure. The oil struggles to stay on the wrist pin/boss because heat chases it away. The taller compression height also directly strengthens the piston crown.
It is a very easy concept.
So in short, to get the cubes and best reliability from those cubes possible, you can go 331 (5.315” or 5.4” rod) or 347 (5.315" rod, NOT 5.4” rod). Get the cubes and mileage you are looking for = 5.315" rod for the 347.
Remember it is your money that you are spending.
Good Luck!
Now, as far as nitrous or supercharged applications, the 5.315" rod in the 347 appears to be better as well. The top piston ring may live a bit longer as well.
Here is some info posted by FastDriver about picking a 3.25 inch stroke over a 3.4" stroke:
I forgot to mention the biggest reason CP didn't like the 3.4" stroke. The ringlands on high boost application pistons has to be lower, which runs you into a bind if the pin is already intersecting the oil-ringland.
There are three reasons as I understand them:
1. The easy explanation is that the higher you place the rings, the more heat that they are exposed to making more prone to fail - there is a thermal barrier between rings that are lower on the piston and the combustion chamber that is created by less efficient burning of the gasses between the crown of the piston and the cylinder wall 2. The thinnest part of matrial at the crown of the piston is the "meat" between the top of the piston and the 1st ringland making this the most likely part of a piston to fail in many applications, and 3. the higher the ring the more prone it is to fail due to mild detonation. As you can see from the article I quoted below, this is not optimal for a naturally aspirated engine:
The "dead space volume" above the piston up to the top of the cylinder wall usually traps unburnt fuel and burns less completely...producing more emissions. Reducing this volume, by moving the top ring up , decreases emissions. The top ring is now exposed to hotter temperatures and must be stronger.
However, moving the top ring up is not just for emissions purposes either:
Here you see a higher top ring and piston pin location placed at the level of the oil ring groove, both of which allows for a longer rod and better rod ratio in these forged race-only strutted pistons.
Moving the top ring down improves durability but at the same time, creates a situation where more entrapment of unburned gases will occur locally in that area, leading to a less efficient burn.
If you want more technical information concerning the subject talk to a tech named Mike at CP. He once explained the subject to me and at the time, I felt I had a very good understanding and I was in agreement with his assessment that I should go with the 3.25" crank instead of the 3.34, 3.4, and 3.5" billet cranks I could get at the time.
thanks so much for the info, im going to get that in a word document and save it. looks like 331 is what i want, it will be a daily driver able car, as well as a little strip time, and little track/auto x. the heat issues just scare me. do 331's sound any different than a 302/306? and are they the least bit less reliable than 302/306? it seems like there arent many.
anyways i really really appreciate that post man, good job.
they sound the same if all other contributing factors are the same (heads, cam, etc.). normally people who run 331's and the like put it in their budget to purchase a bigger cam, aftermarket heads, intake and such to go with the bigger stroke, which definitely change the tone, lope, etc. now you can definitely stroke a completely stock 302 to a 331/347 and keep the stock heads, cam, intake, etc. but you'd be starving it from it's full potential. technically these motors ARE starved though, even as a 302. i wouldn't think they're any more or less reliable, reliability has a lot to do with how you drive it/maintain it.
My personal suggestion is 331 or 347 (with a 5.315" rod for the reasons above) if your staying N/A. They both make similar numbers, with the 347 getting the edge:nice:
For high boost or nitrous use, I would suggest a 331.
More horsepower typically equates to a louder car.
They can be made reliable if you have a good builder This is further explained below.
The difference is you a blow hard!! Save it 5spd!!! :nonono:
Yikes GTO, wrong side of the bed:)
A daily driver is typically a guy with only one car and one mode of transportation. A street car/weekend warrior is typically for someone with another mode of transportation.
My '93 used to be a daily driver, but now it is a weekend warrior.
alright now comeon, im just asking. i said above i want it dd able, meaning i can drive it a ton, and not have to worry about it. i didnt think there was much of a difference between that and a street car. i get the difference. chill out..
Thats some really good info on Rod/Stroke ratio and Compression Height. It seems like for the additional 20 ft-lbs of TQ the 347 just isnt worth the decrease in longevity for a daily driver. Even the 331 CH isnt ideal. The 347 using the 331 piston gives you the same CH but still has a worse Stroke/Rod ratio.
Riddle me this...why would anyone build a long rod 306 given the information you presented us with. there is no advantage to a long rod 306...especially with such a poor CH. Interesting stuff..thanks for posting it!
To be different:D
I read into this a while back, and have since really dismissed it as a worthwhile money spending option:)
By using the 5.315" or 5.4" rod on a 3" crank, (which significantly shortens the compression height as opposed to stock), it does provide different dwell times. It will react slower by pulling away from BDC and TDC slower, as I alluded to in that first post. By having longer dwell times at the top of the piston's stroke, it chances detonation more. Also, larger feeding intake ports don't fit to well with a piston that pulls away slower from TDC. Less velocity, I presume being pulled in by the swept volume which reduces incoming air pull/speed, due in part to reduced piston speed..:shrug:
Throwing the dwell times out of wack as compared to what most aftermarket camshafts are specified for, it really requires a customized camshaft to get the timing back on point.
A lot of trouble and expense for really no gain and really only show any minimal gain at high rpm...
I say, if you are considering that route, go with a stroker and make more power throughout the powerband:nice:
Oh i was never considering that route. I went with a simple 306 for the sole reason of cleaning up the cylinders. I was just wondering why anyone would consider the long rod for a street car.
I plan on running a stroked 351 in the near future...and i was wondering what kind of rod/stroke ratios and CH can be problematic on 351 based strokers. Again street car longevity in mind. Its such a time consuming pain in the but to tear a motor out and rip it down just to change out rings. Seems stupid to me to go with a stroker that will more than likely have oil consumption issues and premature ring wear for a street car. thanks
Maybe a dumb question but I will ask anyway. Could you bore out the motor enough to get similar gains to that of a stroker motor? Wouldn't more bore be less harmful to the cylinder walls then more stroke over a long period of time?
That isn't a dumb question at all, many people do it:)
You could bore a dart block (thicker cylinder walls than stock) to a 4.125" bore and go with the 331 stroke of 3.250" and get a 347:nice:
Some go with a 3.4" stroke and a 4.125" bore for a 363.5 c.i., or you could go with a 4.155" bore on that same stroke, for a 369...:)
That is the same reason I went with a 306, to refreshen after 162,000 miles and because of a budget.
393 --- 4.030 bore. 3.85 stroke. 5.956 rod. 1.608 piston. It uses a 2.300" crank journal. The 5.956" rod is a stock 351 Windsor rod. The 1.608 piston is the same as the 302. The 393 is typically known to save money as compared to the 408.
You can get a 393 with a 6.200" rod, which helps with wrist pin location. I think you need a different size crank journal for that combination:shrug: I can't recall...
408 --- 4.030 bore. 4.00 stroke. 6.250 rod. 1.250 piston. It also uses a 2.100" crank journal.
The 408's smaller journals help fight friction as well...
The 408 moves 4,000 fps at 6,000 RPM.
The 393 moves 3,850 fps at 6,000 RPM.
Those piston speeds are getting awfully quick and produces a bit of strain on the parts, so just keep the rpm down a bit for a true street car in my opinion.
Here is some more stroker information from a Hot Rod Engine Information article:
If the stroke is increased by 10 percent, the reciprocating loads will, at any given rpm, go up by 10 percent. Although reciprocating loads are proportional to the mass involved, they go up with the square of the rpm. What this means is that if the engine is turned at 10 percent higher rpm, the reciprocating forces go up by 21 percent (1.1x 1.1 = 1.21). To offset the inevitable combination of the greater stroke and the desire for more rpm, we need to look for a lighter-than-stock piston. Checking through various manufactures' catalogs looking for pistons that are toward the lighter side is time well spent. Here, ROSS, Mahle, JE and KB are worthwhile starting points. If the piston is offered with a lightweight pin upgrade, then, budget allowing, this is well worth considering.
Rod Ratios:
Rod Divided by Stroke...
302/306 with 5.090"- 1.70
327/331 with 5.4" rod - 1.66
342/347 with 5.4" rod - 1.59
351 with 5.956" rod - 1.70
393 with 5.956" rod - 1.55
393 with 6.200" rod - 1.61
402/408 with 6.200" rod - 1.55
Here is some cool info about short vs. long rods:nice:
Long Rods:
Pro:
Provides longer piston dwell time at & near TDC, which maintains a longer state of compression by keeping the chamber volume small. This has obvious benefits: better combustion, higher cylinder pressure after the first few degrees of rotation past TDC, and higher temperatures within the combustion chamber. This type of rod will produce very good mid to upper RPM torque.
The longer rod will reduce friction within the engine, due to the reduced angle which will place less stress at the thrust surface of the piston during combustion. These rods work well with numerically high gear ratios and lighter vehicles.
For the same total deck height, a longer rod will use a shorter (and therefore lighter) piston, and generally have a safer maximum RPM.
Con:
They do not promote good cylinder filling (volumetric efficiency) at low to moderate engine speeds due to reduced air flow velocity. After the first few degrees beyond TDC piston speed will increase in proportion to crank rotation, but will be biased by the connecting rod length. The piston will descend at a reduced rate and gain its maximum speed at a later point in the crankshaft’s rotation.
Longer rods have greater interference with the cylinder bottom & water jacket area, pan rails, pan, and camshaft - some combinations of stroke length & rod choice are not practical.
To take advantage of the energy that occurs within the movement of a column of air, it is important to select manifold and port dimensions that will promote high velocity within both the intake and exhaust passages. Long runners and reduced inside diameter air passages work well with long rods.
Camshaft selection must be carefully considered. Long duration cams will reduce the cylinder pressure dramatically during the closing period of the intake cycle.
Short Rods:
Pro:
Provides very good intake and exhaust velocities at low to moderate engine speeds causing the engine to produce good low end torque, mostly due to the higher vacuum at the beginning of the intake cycle. The faster piston movement away from TDC of the intake stroke provides more displacement under the valve at every point of crank rotation, increasing vacuum. High intake velocities also create a more homogenous (uniform) air/fuel mixture within the combustion chamber. This will produce greater power output due to this effect.
The increase in piston speed away from TDC on the power stroke causes the chamber volume to increase more rapidly than in a long-rod motor - this delays the point of maximum cylinder pressure for best effect with supercharger or turbo boost and/or nitrous oxide.
Cam timing (especially intake valve closing) can be more radical than in a long-rod motor.
Con:
Causes an increase in piston speed away from TDC which, at very high RPM, will out-run the flame front, causing a decrease in total cylinder pressure (Brake Mean Effective Pressure) at the end of the combustion cycle.
Due to the reduced dwell time of the piston at TDC the piston will descend at a faster rate with a reduction in cylinder pressure and temperature as compared to a long-rod motor. This will reduce total combustion.
It appears to be more pros than cons for the shorter rod combination:)
