GTfoxbod89
so i got everything connected........ everything looks great and now the cable doesnt travel enough to open the throttle to wot.?!?!? wtf it seems the original fox cable has a travel limiter on it? is this true?
what are the advantages of doing this swap?
What you want to do is cut the stock TPS connector off exposing three wires. There should be a gray wire with a red stripe, a gray wire with a white stripe and a brown wire with a white stripe. The fox TPS connector (the bottom connector in the picture) will have three wires also. A green, orange, and black wire. Here’s is how you want to wire them together:
Green wire – Gray w/white stripe
Black wire – Gray w/red stripe
Orange wire – Brown w/white stripe
I have a 95 auto. do I get the Fox 5 speed cable LRS-9758A or fox auto cable LRS-9758B.
That's good because it has the cable AND bracket. Some guys are getting $10-$20 just for that bracket plus shipping.
I have the Pigtail for the TPS if you want, I just havent got to list it yet.
Thanks
RC
That would be great. then all i need is the fox TPS right, then splice the bottom connector and it'll be done right?
