Ok I really am stuck on this step. I might have asked up here before but I don't think I asked the right question. I have a stock 302 89 5.0 stock roller cam, hydraulic roller lifters(new/dry) with e7 stock head's & I wanted to install these scorpion 1.6 pedistol roller rockers but I gotta know,What kind of lftr should I be using to check m sweep patterns? I was using the new dry lifters but I read I have to use a hydraulic solid lifter so I converted one by taking spring out took that ball off and flipped that cylinder housing around put the clip back in but when I used it this time those pushrods I thought were good were really tight! I couldn't rotate the with my fingers at all with the vavles down closed. So I gotta know before I even attempt to use the pushrod legth checking tool with out knowing what lifter to use hydraulic new dry or hydraulic coverted to solid?
