- Mar 30, 2005
- 4,749
- 95
- 134
With the mad tyte 4R70W I just powerbrake it enough to get them spinning and then just ROAST 'em through the gears
timeless2 said:Some have forgotten a crucial element: use 2nd gear.
McTeague said:With the mad tyte 4R70W I just powerbrake it enough to get them spinning and then just ROAST 'em through the gears![]()
Well, it works best on hot asphalt when there is some melting on the surface.PlatinumDevil said:what? teach me, i suck at Auto burnouts, i grew up on the stick (literally...)... autoburnouts i just hold brake and hit the gas till i hit 5000 and roll away... but it usually only spins 1 tire, then i try varying with D or 1, seems to be the same to me, it kicks it out hard into second but the burnouts always over before im going fast enough for second... maybe its my lack of gears? Its not a lack of power, it runs really strong. For some reason it tends to lock the rear end only when i just floor it, no brakes... and the burnouts just as long. Dont get me wrong, spinning the tires or a tire till 5000 leaves quit the smoke show but its not what i want to be doing.
I was so good at manual burnouts too, even got my 4spd manual 2.3 to do some nasty ones. Now THAT took alot of practice and clutch control.
Uncle Meat said:I just roll into the throttle and press lightly on the brake!? Why all this popping of the clutch nonsense?
U.M.
Now that guy can drive...I would love to have an area to do that. Im pretty good at keeping cars straight and making them do what I want
hotmustang331 said:Now that guy can drive...I would love to have an area to do that. Im pretty good at keeping cars straight and making them do what I want
This is where the thread should have ended, since it was the only right answer. That whole dumping the clutch, then diving on the brakes thing is something you see 16-year-olds doing when they first get their license. Very amateur.....you'll be a real hit with the ricers at the track if you do it like that.Skidzz said:It's very easy.
1. Left foot on the clutch
2. Right heel on the brake, with right toe on the gas.
3. With right toe, rev up to about 3500-4000 RPM's.
4. Slip out the clutch, don't pop it.
5. Move left foot from clutch to brake and put right foot all the way on the gas.
6. Keep it around 4000 or so RPM's for about 6-7 seconds and then slowly ease off the gas and ride it out.
7. Enjoy the wonderful aroma of burning rubber.
Gearbanger 101 said:This is where the thread should have ended, since it was the only right answer. That whole dumping the clutch, then diving on the brakes thing is something you see 16-year-olds doing when they first get their license. Very amateur.....you'll be a real hit with the ricers at the track if you do it like that.![]()
