How to get 10#'s of boost?
WhiteSN95
142
I just got my Vortech V2SQ complete kit in the mail today. Early Christmas for me. I want to make ten pounds of boost with the system. I am going to go with an FTI cam, anderson power pipe as well as the fox conversion. I will upgrade to an 80mm Mass air and a 75mm Throttle Body. My ignition will be upgraded as well as my fuel system so that isn't going to be an issue. Which pulley or pulleys will I have to put on to make 10#'s? i know the anderson pipe and the fox conversion will help with boost but think i am going to have to change the pulley to get my goal. There are so many size pulleys out there that i am lost on which ones to get. While I am on the issu, I am so excited about the blower, what HP/torque numbers you think i can get with my mods and the 10#'s? and are low 12's feasible on DR's? Sorry for all the questions guys but i am excited about getting this thing together and see what I can do with it
Your set up is fairly close to mine. Before I make any HP or torque predictions, be conservative and err to side of caution with timing and a/f. Your biggest HP "adder" will be a spot on WB dyno tune. With that said 325 to 350 HP and Torque rear wheel.
You'll also want 42# injectors, and make sure your MAF is calibrated as such. I went with Pro-m.
You should be able to make 10 psi with the stock pullies, the power pipe and your mods without too much issue. We were able to see 13-15 psi with an S-trim on a H/C/I 95GT once we added the power pipe.
yeah same thing these guys said, get a power pipe and you should see #10 PSI. My blower is rated to 8-10 with the stock pully but you and every blower will loose some due to slight belt slippage but the PP takes care of that.
