89CopCoupe
Banned
Here's a combo 5.0 Mag did - it made 425flywheel horses/435lb ft ... was very streetable and had a broad power curve (useable power)
DSS 347 ~ Comp XE266HR ~ AFR 185 ~ Comp 1.6rr ~ RPM II ~ BBK 70mm ~ Pro-M 75maf ~ FRPP 30lbers ~ BBK 1-5/8" long-tubes ~ MSD distributor ~ 42psi fuel pressure ~ 14* degrees initial ~ 9.8:1 compression.
99% of the cars on the road couldn't touch you.
The only down side they stated was it's inability to blow clean emissions (cam)
On a 306, get a good h/c/i setup with 9.0:1 and charge it
