yes, it does.67coupe351w said:First off, changing a cam is not going to change your firing order "Depends on the cam"...
Second off, um, yeah it most certainly can. So.........would this be your first mustang?
No, the crank does not change in this case.Edbert said:Not only the cam but the crank will change firing order right?
Pakrat said:Second off, um, yeah it most certainly can. So.........would this be your first mustang?
You come in with an affirmative "First off let me correct you all as I know exactly what I am talking about statement" but I'm the a$$??????? Too funny.
At least I'm not a dumba$$ then. If you hadn't sounded so snippy in your jerk tone like there was no way you were wrong I would likely have said nothing, and I point out that at least I ended it with a friendly tongue sticking out unlike yourself. Just because you're mad at yourself for f**king up and getting called on it, don't blame it on me.
Pakrat said:Hey 2cents from a nickel, what a surpirse.![]()
Look, I've worked very hard for several years at being a dick, and not you or anyone is going to demote me back to a$$, got it? :damnit:
