  • 1994 - 1995 Specific Tech
How to make a custom cai?
  • Thread starter Thread starter sage2k
  • Start date Start date Jun 4, 2007
sage2k
645
Baton Rouge, LA
Jun 4, 2007
  • Jun 4, 2007
I want to make a custom 4 inch pipe cold air intake using a lightning maf
any suggestions? Particularly curious on what i should do for the ACT sensor and for the ventilation tube that goes to oil fill tube? drill and jb weld them
M
mgcook
40
  • Jun 4, 2007
i made a 3" intake
i used 2' of 3" pipe from the muffler shop
then i cut about 20" for the main part, jbwelded in a piece of rubber for the IAT and a brass fitting for the breather tube line
then i put a 45* bend coupler at the end and used the other 4" of pipe to connect to that, then i put another coupler to connect to the MAF then i put my filter right on the end of the MAF
its about the same price as an ebay intake, but i dont have any 90* bends like those only a 45* bend, and my filter sits almost at the fog light hole
it works like a champ for me and it was cheap. maybe that will help you some.
edit* i can get you some pics if you'd like
drakesdad
961
Oregon OHIO
Jun 5, 2007
  • Jun 5, 2007
I'm interested in seeing these pics.....
Blackened302
1,439
South TX
Jun 5, 2007
  • Jun 5, 2007
+2 for the pics
i'm trouble finding big enough couplers. Oreilly/Advance/tehZone has some, but they're ricer-ish 2" couplers.
where's everyone getting their's from?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jun 5, 2007
  • Jun 5, 2007
Punisher302 said:
+2 for the pics
try e-bay.
M
mgcook
40
  • Jun 5, 2007
Punisher302 said:
+2 for the pics
you ccan get 3 or 3.5 off ebay..they arent cheap...but i have a friend who gets discounts on them
i'll get some pics up here shortly
its a pretty basic concept
tb -- coupler -- pipe -- 45* coupler -- pipe -- coupler -- MAF -- airfilter
for the IAT i just took a piece of rubber tubing that fit, cut it to about 3/4" with a hole in the pipe so that the sensor sticks through just like the OEM intake. Then I just put some JB weld around the rubber to make it stay in place..to make the IAT sensor stay put i just used a small clamp
for the vent tube you can just go to lowes or home depot and get a fitting that is big enough. then drill a hole in the intake pipe big enough. then cut the fitting and JB weld that. you can also take a small hose clamp here to make sure it stays on also.
its simple, and cheap. not the best looking thing, but it works.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 5, 2007
  • Jun 5, 2007
Very Basic
Very Simple
Very Cheap
Nothing but pvc pipe and plumbing couplers you find at hardware stores
You can do the same with big truck exhaust pipe but you gotta weld
You just gotta get creative and get busy
Here is a pic or two of mine
My focus was on function before looking good
and
I've yet to get around to making things look better
Maybe you can get some ideas
Grady
drakesdad
961
Oregon OHIO
Jun 5, 2007
  • Jun 5, 2007
Mr. Crockett........DFW VIce.... ..sorry..blame JT..
That's a great idea.....do you have any pics while you were cutting the fender well.....? and I think I see that you still have the breather line hooked up......and is the electronics for the MAF out of site....underneath maybe?
Wil
juiced_94gt
1,143
Southern California
Jun 5, 2007
  • Jun 5, 2007
Punisher302 said:
+2 for the pics
I got all my reducers and couplers here http://www.siliconeintakes.com/index.php?osCsid=52d514f467509ee3d6b56db8e15c525b
juiced_94gt
1,143
Southern California
Jun 5, 2007
#10
  • Jun 5, 2007
  • #10
final5-0 said:
Very Basic
Very Simple
Very Cheap
and
Grady
Whats that hose on your oil fill tube??? what valve covers are you running?? are they Fox valve covers?? im interested in seeing your oil fill tube.
Suspect
256
GA.
Jun 5, 2007
#11
  • Jun 5, 2007
  • #11
another link..http://www.intakehoses.com/
ill have to make one here soon also, so post pics if u have em.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 5, 2007
#12
  • Jun 5, 2007
  • #12
Wil
I'll try and list every item and the details
Just because its you Will
3" schedule 40 pvc pipe
2 Fernco rubber couplers
1 90 degree hose fitting
strap Aluminum for bracket
4 hose clamps
The inside diameter of the ProM 80mm shorty meter and 3" pvc pipe
was found to be almost exactly the same.
The oem meter mounting hole and bolt was used for the new bracket
The oem filler neck hose was reused
The act and 90 degree hose fitting was threaded in the rubber coupler
with a very tight fit by drilling a hole much smaller than needed
The bracket was just bent as needed
I got no pics of cutting a hole
I mean ... Come on Will ... You just cut it till it fits
Sorry ... I just had to have a bit of fun here
Seriously ... I used a die grinder and a cut off wheel. Removed the
material a little bit at a time and trial fit until it was good to go
You don't see the electronic module cause it is on the back side.
Yes ... I run all emissions equipment
and
The oem closed pcv system
I think that is it my friend
Lemme know if you got more Q's
but
I already told you more than I know about it
I just got it Crockett ... DFW ... Vice
I'll have you to know Will :Word:
I do not own a White or Yellow or Pink jacket
Grady
drakesdad
961
Oregon OHIO
Jun 5, 2007
#13
  • Jun 5, 2007
  • #13
thanks Grady....I just replied in the other thread........I'm gonna finish a few home plans over my vac.....and then tackle trying to fab something up.......
U know...pink is coming back........but that is a fad I can live without..............unlike the low cut jeans of the 70's.......but if parachute pants come back........I'm gone.....
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 5, 2007
#14
  • Jun 5, 2007
  • #14
Fox VC's
Cut the tube in half and used a ricer car radiator hose to reposition it
I ain't tearing it all apart to just shoot a pic
Its just simple ole common sense hot rodding at work
If you had the vc on the motor .......
it would be very obvious to you ..... no doubt about it
Lemme know if you got more Q's my friend
Grady
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
  • dan50
  • Jul 18, 2026
dan50
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
