- Jan 8, 2004
- 51
- 0
- 0
OK, I installed the Accufab TB/Plenum combo and the Steeda CAI (sweet mofokers), but my car feels like way too accelerated.
THe way I checked the TPS voltage was putting a thin paper clip in the center cable from my TPS, I then went ahead and connected my ground from my voltmeter in a screw that I have grounded in my car (I use this screw to ground my N2O kit, it does work) and then with the positive from the voltmeter I touched the paper clip and it read 0.98V.
I know that this is correct (.95 - .99), but I feel my car waaaayyyy agitated.
It idles like at 900-1000 RPMs (when it used to idle like at 600-700), and when you step on the gas it takes like 3 seconds for it to start dropping from wherever it is at that time.
For example if Im going at 2500 RPMs and I get off the gas it stays there for like 2 seconds and then starts dropping to idle (900-1000).
How can I fix this?
Once more thing, when I step on the gas I hear a hissing sound coming from where the Steeda filter is. Is this normal (I know is a bigger filter and no silencer whatsoever)
Sorry for the LONGGGGGGG post.
Any help will be greatly appreciated. TIA!
How can I fix this?
