just bring it over, and il pull it in 5 minutes..
actually, bad idea.. my house is bad luck for your car.
steps are:
-Drill out the 2 rivits up front, on those 2 bumper mounting tabs
-pull the plastic bottons from the bottom
-Unscrew the self taping, phillips head screws on the fender lips (2-3? each side)
-Reach around in the innder fender, and unbolt the nuts that mount the bumper on the fender. These are 10mm nuts, possibly 11mm ( forget) there are two on each side.
-Then gently pull forwards, while someone wedges a screwdriver under the bumper tabs, under the headlights. Youll see what i mean, once this causes you problems.
Should pull off from there.
Once youve done it a few times, it takes all of 2-3 minutes to pull off/put on
