  • 2005 - 2009 Specific Tech
How to remove the e-brake handle
  • Thread starter Thread starter GalaxieWarrior
  • Start date Start date Nov 21, 2008
GalaxieWarrior
64
  • Nov 21, 2008
Searched the site and the internet no luck. Thought I stumbled on it a while back but no luck now. Mines rattlin pretty good
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Nov 21, 2008
  • Nov 21, 2008
Click on "video installation" on this page ( they show how right after they remove the stock shifter): Mustang Shift Handle
STANGmole
245
Portland, OR
Nov 21, 2008
  • Nov 21, 2008
Simply put, you pull the plastic cover apart carefully.
It's easier if you remove the console but I did it without taking the console apart.
The MGW website has a detailed video.
GalaxieWarrior
64
  • Nov 21, 2008
Thanks guys. Gonna run console-less for a bit see how i like it
L
Lennyvb
57
Centerport, NY
Nov 21, 2008
  • Nov 21, 2008
I might do it this weekend. Is there a trick to getting the pieces to separate? Did you use just your hands?
STANGmole
245
Portland, OR
Nov 21, 2008
  • Nov 21, 2008
I just used my hands. You kind of have to squeeze and twist the two pieces apart though (move them in opposite directions). If you try to pull them straight apart it's near-impossible.
It's also very hard to do without removing the console (especially reassembling the handle with the console in place) but I was able to do it so it can be done.
L
Lennyvb
57
Centerport, NY
Dec 1, 2008
  • Dec 1, 2008
Finally got around to doing it (the dynomat ebrake fix) and was amazed at what a difference it made. The noise I thought was coming from the tranny went away immediately. Funny how noise travels. Everyone with an aftermarket shifter should do this, regardless of what brand shifter you have.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Dec 2, 2008
  • Dec 2, 2008
for ease of information, where did you install the dynamat?
L
Lennyvb
57
Centerport, NY
Dec 2, 2008
  • Dec 2, 2008
Go to the MGW site Mustang Shift Handle and download or view the video installation. About 5 minutes into the video they show the fix. You need two small pieces of dynomat. One thin strip goes on the front of the brake handle facing the radio, a triangular piece covers a small hole on the driver's side. The video makes it clear. Made a big difference in my car.
R
Interior and Upholstery How to remove seatbelt torx screw
  • Riley Barth
  • Jul 6, 2026
Fox 5.0 Mustang Tech Jul 13, 2026
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
J
Speedometer cable
  • Jimwbx
  • Sep 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2025
Brakes How do I get the e brake cable onto the disc brake caliper??
  • AnthonyA1234
  • May 2, 2025
Fox 5.0 Mustang Tech May 2, 2025
AnthonyA1234
