How to remove the factory CD player in an '04 F-150?
Remove the rubber pad fromt the top of the dash....
Then use a very thin flatblade screwdriver or I use a pic tool... Pry outward on the dash bezel FROM THE TOP!.. The first set of clips are about 3" down...If it has never been off before, they will be REALLY tight... It will feel like it is going to break, then it will let loose... After you pop the top loose it will be really easy to get the rest off...
Goodluck
