Hi all:
I'm having a big issue with error code #34, this after I cleaned the inside of the throttle body. I recently replaced the EVP sensor. I tested it yesterday and it shows 0.45 Volts between EVP and Signal Return cables, the book says that it should be 0.67 Volts or less so it is good.
I checked resistance on the on the EGR Vacuum Regulator (EVR Solenoid) and it shows 42.3 Ohms (I learned it should be between 30 ish and 70 Ohms so it is good.
The EGR valve holds vacuum with no leaks. The only thing about the valve is that I had to smash it a bit ob the side to be able to fit my Kirban AFPR but there is no interference when applying vacuum.
I ran a scan and it shows code 34 then I errased the code with the scanner and scanned again and the code still there, then I disconnected the battery and without starting the engine ran a scan again and the code still there!!!!!!
what do you guys think I should do now. I'm stumped!!!
Please need your ideas, I searched the these forums and all over the net and can't find nothing that helps.
Please help me!!! Nick
