How to swap drive shaft yokes?
Is there a special way to swap drive shaft yokes? I'm starting my TKO swap tomorrow afternoon and need to have the yokes swapped as the TKO requires a 31-spline yoke. Can I do this myself or do I have to take it somewhere? If so, where do I have to take it? How long does it take to do?
ExplodingGopher said:
You need to take it to a shop that specalizes in clutches and/or driveshaft service. I had to put a C6 yoke on my driveshaft with the 8.8 rear flange and have it shortened 3 inches. They have to balance it as well. So unless it'll only be turning around 100-200 rpms, take it to the professionals.
What about a reputable transmission shop?
i dont think you have to get it balanced if youre just changing the yoke. but you might as well just take it somewhere and get it done. its a headache. but if you do it yourself its just like changing the u-joints except your changing out the yoke too.
You should really have it balanced. (Especially if it's the original shaft) The OEM shaft is know to bend similar to a jump rope once a lot of power is put through it.
Plus, wouldn't you want to know that you don't have to worry about the shaft after you install it..?
Changing the yoke is essentially just the same job as changing the u-joint.
Make sure you have the proper u-joint, and then just take it apart and put it back together.
If possible, use a press, or a u-joint c-clamp type tool. A hammer will do if you are careful. A M or BFH is best.
Or, most auto machine shops have a press and can do this for a nominal fee.
The u-joint should be located closely enough by the snap rings so that re balancing is not necessary.
