How would this setup be with speed density?
Rick's Fords
95
The car currently has the following:
3.73's
K+N Big Cone
BBK Shorty Unequals
Offroad H w/ High Flow Cats
Dual Chamber Flowmasters
Underdrive Pullys
I was thinking of picking up a 70MM TB kit from BBK for $180, and a Trickflow intake. Also wanting to put on some GT40 heads.
Couple of friends want me to turbo the motor, but I'm only looking for 300-350 HP, pretty much my daily driver right now.
My question is, I've seen/heard some comments about changing the airflow on a speed density setup being bad. Do I need to convert it to MAF in order for this setup to be beneficial? Also, anyone know any rough numbers this setup would pull on a dyno?
Thanks for your time.
you can either run mass air or you can take it somewhere and have the SD ecu reprogrammed. there are some people on here that have changed the induction on their cars and are still running SD, i'm sure they'll chime in. even with whats on the car already, the gt40's, the trickflow intake and the bbk throttle body you won't be at 300rwhp. it'll definitely waken up your car though. i say go for it!
with tht setup it should be sd friendly maybe the trick flow intake might mess wit it some but not much speed density starts having alot of problems when u go with a cam along with ur setup. but even then u can get a tweecer burnt to take care of tht but in the end if ur looking for later on down the road when u may actually go big then go ahead and convrt to mass air its relitively cheap and saves u alot of but hurt in the long run.
guess ill chime in..As in my sig i have quite a bit of mods... for SD anyway and no problems for me, but im guessing if you went through with the whole TF package you would have to get a new chip burnt or something
