Actually I got the frpp kit that includes nodular cast iron crankshaft 3.40 in. stroke,
KB hypereutectic flat top pistons,
Federal Mogul rod and main bearings,
Grant piston rings,
and Fel-Pro gaskets.
I'll be doing the machining balancing and blueprinting at my college. I'm in a class "high performance engine blueprinting". So I'll be retaining my current block. I was thinking about using a main support girdle also. The x cam looks better with the .542" lift. The heads come assembled so i'm just going to leave the springs, next semister I'm going into "advanced clyinder head porting and airflow carecteristics" so I might mess with the springs them when I port them. The twisted wedge's are good up to .600" lift
The street heat will be holding me back huh?
Should I go with 24lb injectors? I really don't know when to step up them up. And do they really require a calibrated MAF sensor to work right?
Thanks, sorry to ask alot of questions in one thread, but I want to get the right parts the first time. I figure you guys who have been there, done that will give me the best feedback I could get.
