How's This Look (suspension)
DarkHorse02GT said:
Are the Tokico Mach 1 Shock and struts worth it if I plan on lowering the car with H&R supersports or Steeda Sport Springs? And would I NEED cc plates?
I've had the H&R SS/Mach I combo for a little over a year and it is great. Can't beat it for the money. Yes, you will need CC plates.
DrK MrK iV said:
What about the mach1 shocks/struts and some springs? Oh and CC plates. Should improve handling a lot, right?
The cc plates are to get a proper wheel alignment when lowering generally more than 1.5 inches. Going with Bulitt, Mach 1, or Pro Kit you will not need them.
Changing springs and shocks/ struts will make dramatic handling improvements. When lowering it is a good idea to also do (a) offset rack bushings to align the steering rack to the new ride height, (b) new spring isolators (you're in there, might as well put some really good new ones in there -- I wish I did), and (c) a lower pinion snubber (most spring sets come with one). These are all very cheap and easy to install.
