OK the GT is kinda weak after a bad day at the track a few weeks ago, but i talked myself into gettin her dynoed NEway....and glad i did. she put a pittiful 215hp @ 4650 rpm thats with a low 150lbs of pressure in two of the 8 cylinders when thier supposed to be at 165lbs of pressure. anyway while i was there a guy told me he'd sell me his 70mm throttle body and a C & L intake plenum(the thingy the throttle body bolts up to) for 150 bucks is this a good price??? he for sure put it on 6 weeks ago then bought a cobra so he's parting out the GT its on. supposedly in cant have more than 1000 miles on both pieces. should i get it?????? and what would the HP gain be after i fix the compression issue???
BTW 215 to the wheels with a 98 GT in the shape mine is in aint bad at all
if i can squeek 250 at the wheels and delve into the compression issue (if springs we fix, if valves just babby the chite outta her) id be happy. the reason P&L on the rings is so cheap is that the guy thatd be doing the work requires half what the cheapest shop will quote me and a case of beer. best part ive only had 1 problem with this guys work and
