HP question
  • Thread starter Thread starter RATM
  • Start date Start date May 25, 2005
R
RATM
35
May 25, 2005
  • May 25, 2005
I am the recent new owner of my 3rd 5.0 and have a HP question that I hope someone could give me help with. The car I bought is a 92 LX coupe with a new motor that was put in in Jan '05 (I have the receipts). here is what it came with...
302 block bore to 306
hydraulic rollers
1.7 RR's
B303 cam
RPM performer heads
RPM performer intake
MAC shorty headers
MAC H pipe
MAC mufflers (dont know what model but they are VERY loud)
holley 750 DP
MSD 6AL ignition.
4:10 gears
HD T5 tranny
couple of questions...
The builder of the motor (Bob's Speed Products in FT. Lauderdale) said that it had 375 Hp and 350 Lbs. Torque (not rear wheel) does this seem right?
With this set up, and running DR's, what could i expect to run in the 1/4. The guy i bought it from showed me two time slips that he said were his one said 11.86 and the other 11.80 (close friend of my best friend so I beleive they were his).
With this motor set up, would i benefit at all from long tubes and/or and X-pipe?
thanks to all who respond.
Daniel50
716
Discovery Bay, CA
May 25, 2005
  • May 25, 2005
that horsepower rating seems a little high. its possible though. stock cam? with the stock cam i say no. but with 375 to the motor and roughly 340 to the wheels and a good 60 ft those 1/4 mile times are possible.
R
RATM
35
May 25, 2005
  • May 25, 2005
the B303 was the stock cam?
Scott_B
"1 Arm Wonder! "
4,197
NS Canada!
May 25, 2005
  • May 25, 2005
no
skip nay
110
Chambersburg Pa
May 25, 2005
  • May 25, 2005
I had...
F cam
RPM heads
Air Gap intake
650 doublepumper
msd 6al
msd dist.
flowtech 1 3/4'' long tubes
Dr. Gas X-pipe
2.5'' dynomax mufflers and tubes
underdrive pulleys
t-5 with pro 5.0 shifter
centerforce dual friction clutch
3.55's
3400 lb 88gt with me in it. I had a lifter that wouldn't prime up at all and kept knocking the rocker off of the spring and never letting any air into the number 6 cylinder since it was on the intake valve. I went 12.6@106. I have got on the innernet and both calculations for speed and et for my weight was around 338-345hp. That was on seven cylinders though.
I hope this helps you out. I would like to know what it would've ran on all 8 but is already out due to putting in a 398windsor
R
RATM
35
May 25, 2005
  • May 25, 2005
skip nay said:
I had...
F cam
RPM heads
Air Gap intake
650 doublepumper
msd 6al
msd dist.
Dr. Gas X-pipe
underdrive pulleys
3.55's
it does, and that sucks about your run. How did you like the F cam. ie., idle quality and such.
maverick0716
3,924
Chilliwack, BC, Canada
May 25, 2005
  • May 25, 2005
That hp number might sound right if it was dynoed with no accessories or anything. With it actually in the car behind a 5 speed you'd probably be looking at around 300-320 rwhp.....which is entirely possible. I'm about to install Performer RPM heads (60229) and a Comp XE cam and roller rockers on mine....hopefully it'll make decent power.
R
RATM
35
May 26, 2005
  • May 26, 2005
bump
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Yesterday at 1:30 PM
squeak93
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 5:48 PM
from6to8
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
