Hp question?
shifterpilot5.0
49
Im almost done building my stroker, and I keep getting different hp # from the guys at the speed shop...
Any one running this combo, if so do you have a close hp # I can look for?
Victor Jr heads 60cc mild porting, trick flow stage two cam, 1.6 roller rockers, KB flat top pistons, Scat 347 stroker kit, windage tray, mac long tubes, off road h-pipe, and flow masters, 93 cobra intake (extrude honed) 75mm throttle body, 80mm mass air, 24 pound injectors, custom cold air, electric fan, underdrive pullies, etc...
I have been told 350-400 to the ground with the T-5
I think it sould be higher, mabe because i have spent alot of money and expect more... I would like to hear what you think. Thanks!!
I see 331/347's on the chassis dyno all day long. They range from 350-400. anybody hitting 400 has heads that flow over 300cfm, a race ported intake, a HR cam with 230/240 duration. There was a guy on corral.net that claimed to get w/ a 347 - 466/450 @ the RW with a HR, a Victor race intake and AFR 185 heads on 10.7CR and pump gas but I don't for one minute believe it. I do not care what any magazine says or his dyno chart.
The guys at ur speed shop r correct, 350-400.
The only problem I see is ur running a 302 intake on a 347. Even if it is extrude honed that just smooths out the intake surfaces, it does not open the intake up to flow more cfm. I would have TMoss do a full race port on the Cobra or sell it and go Victor EFI. and if u really want more power go to a Comp cam XE282HR, one bad ass off the shelf cam.
My old 347 stroker had AFR 185 hand ported heads, Ported downs lower, Comp cam XE282HR, 30lbers and put down 400/400 @ the RW, NA on 10.3:1 CR and pump gas.
I have very similar setup and made 475hp at the crank
my cam is very similar to the TFS stg2 cam.
VicJr.'s flow a little more than 185's though.
Your intake is VERY restrictive, you need a TrickFlow R series
or Holley - ( Holley is best )
The Cobra intake is only good for about 400-425hp, its going to
hold you back at upper rpms....
you should easiley make same power, figure 370-390rwhp with better intake
also...............
24# injectors are probably not enough, I'm moving up to 36's myself.
and
Your T-5 will probably not last very long.....................
