hydro boost nightmare
  • Thread starter Thread starter cherryflavored
  • Start date Start date Jun 18, 2018
C
cherryflavored
phoenix, az
Jun 18, 2018
  • Jun 18, 2018
WE HAVE A 2001 FORD MUSTANG GT THAT WE RECENTLY HAD TO PUT NEW FRONT TIMING CHAINS AND TIMING CHAIN GUIDES ON. AFTER GETTING CAR BACK TOGETHER WE GET IN TO SEE HOW IT RUNS AND WE CAN'T GO ANYWHERE OUR BRAKES ARE LOCKED UP. WE HAVE CHANGE THE MASTER CYLINDER AND BLED AND BLED AND BLED THE LINES AND TYHE POWER STEERING PUMP AND STILL WHEN WE START THE CAR THE BRAKE PEDAL GOES TO THE FLOOR AND THE BRAKES ARE LOCKED. WE HAVE TRIED BLEEDING THEM WITH CAR ON AND OFF. REBUILT THE POWER BOOSTER STILL NADA.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jun 18, 2018
  • Jun 18, 2018
How are you bleeding them?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 19, 2018
  • Jun 19, 2018
The Ford Service manual pin point test "D" first items says:
PINPOINT TEST D: HYDRO-BOOST ERRATIC OPERATION, STICKS, BINDS OR GRABS
Check for obstructions in power steering return hose and connections between the power steering pump reservoir and between the power steering pump reservoir and the hydro-boost power brake booster
Since this problem started after the timing set repair I would start there. For example check the power steering lines where they go to the power steering cooler around the radiator core support. I could easily see a case where the line could get crushed or kinked while doing a big job on the front of the motor.
A
AORTIZ10
  • Jul 2, 2018
is the power steering affected at all by this the brakes get its vaccum from the power steering pump
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
G
66’ drum bleeding
  • Geno66
  • Sep 1, 2025
Classic Mustang Specific Tech Sep 8, 2025
GOvert
G
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
