I Am Committing to Retrofit
  • Thread starter Thread starter 69Rcode_Mach1
  • Start date Start date Dec 22, 2005
69Rcode_Mach1
1,473
Salt Lake City, Utah
Dec 22, 2005
  • Dec 22, 2005
Okay guys I am getting my money together to get some of these "christmas presents" for the car. Now I am committing to some vertical link bar lifters for the hydraulic roller retrofit into a 1974 351 Windsor. I just want to confirm from the experts that these will work with a standard base circle cam before I spend $420(I just don't understand how them being vertically linked doesn't require taller lifter bores, if possible I would like someone to explain it to me), if not I would rather do spider and dog bones assembly. I am also calling summit racing to get help from their tech line, but want to be safe and check with you guys too. Here is a link to the part: http://store.summitracing.com/default.asp?target=partdetail.asp&part=FMS-M-6500-S58&FROM=MG
D
D.Hearne
11,730
south louisiana
Dec 22, 2005
  • Dec 22, 2005
Call Ford Racing's tech line and ask them. I'm 99% sure Crane's retro fit lifters work with std base roller cams.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Dec 22, 2005
  • Dec 22, 2005
I think the reason they don't need taller lifter bores is because you MUST use custom pushrods(shorter). They are probably available for these roller lifters but it is worth checking into the price.
302 coupe
1,952
Macon, Ga.
Dec 22, 2005
  • Dec 22, 2005
looks like the right lifters to me. You'll have to remove the heads to install them, other than that they should drop in. There is a chance you'll have to some slight clearancing on the block, but you probably won't unless you have some excessive casting flash.
Say goodbye to wiped lobes.
steel1212
1,180
Frankfort, Ky
Dec 22, 2005
  • Dec 22, 2005
I'm just wondering but doesn't crower sell the same thing for around 300?
these: http://store.summitracing.com/default.asp?target=partdetail.asp&part=CRO-66335-16&FROM=MG
rbohm
6,698
550
204
tucson,az
Dec 22, 2005
  • Dec 22, 2005
1: be absolutely sure that those are truely link bar and not dog bone lifters.
2: if those lifters are shorter than stock, then you can use a standard base circle cam. if however they are the same length as stock, then you need a smaller base circle cam as the lifter bores are not tall enough to prevent the oiling groove from poping out of the bore and the engine losing oil pressure.
latamud
791
Tampa, FL
Dec 22, 2005
  • Dec 22, 2005
here's a good thread on coral
http://www.corral.net/forums/printthread.php?t=301843
I did a searck for "roller lifter 351w" and one up near the top was my first question when getting into my roller 351 project.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Dec 22, 2005
  • Dec 22, 2005
I asked this question elsewhere and was told that "only" the Crane version will work in an early block. Luckily the FMS ones you linked are probably the same ones. They will work fine with a standard base circle cam. Here is the discussion:
http://bbs.hardcore50.com/vbulletin/showthread.php?t=30333
dennis112
1,561
36
79
Dec 22, 2005
  • Dec 22, 2005
N/m
10secgoal
2,801
San Diego
Dec 22, 2005
#10
  • Dec 22, 2005
  • #10
You sure ? Is it because of the links ? I can get my lifters out by lifting and slightly turning them.
69Rcode_Mach1
1,473
Dec 22, 2005
#11
  • Dec 22, 2005
  • #11
I called summit and they said that it would work. They are machined with the oil passages lower so that the oil does not come out. Crane is the same as Ford though from what I have heard. We shall see what happens. Thanks for all the help guys.
steel1212
1,180
Frankfort, Ky
Dec 22, 2005
#12
  • Dec 22, 2005
  • #12
So I guess the ones I posted won't work?
69Rcode_Mach1
1,473
Dec 22, 2005
#13
  • Dec 22, 2005
  • #13
I posted about those many times steel, they won't work because they are just regular roller lifters. After I called summit and crower to understand what was going on, but crower was right there was a problem in their book, and summit went and changed the description. If you look at the link section on it, it is changed to no link instead of vertical link. The picture is a chevy lifter. Bugs me that they have that picture on it.
classic boost
709
canton, oh
Dec 23, 2005
#14
  • Dec 23, 2005
  • #14
those look just like the crane lifters that i'm using. they work with a standard base circle cam.
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
P
Engine 95 Gt 5.0ho Build-up
  • psychorugby
  • Oct 19, 2011
  • 3 4 5
38K
1994 - 1995 Specific Tech Jul 20, 2016
Dirt bike kid
Dumb oil pan capacity question
  • jcode68
  • May 6, 2009
2K
Classic Mustang Specific Tech May 8, 2009
jcode68
Quick question on Pistons and lifters with trick flow H/C/I
  • 02stangman
  • Apr 19, 2009
Fox 5.0 Mustang Tech Apr 25, 2009
02stangman
R
91 GT 408 Stroker project - advice on heads and Intake
  • redrocksdrew91
  • Dec 22, 2009
5K
Fox 5.0 Mustang Tech Dec 23, 2009
rbonella
