- Jul 14, 2004
- 45
- 0
- 0
Ok I can not take this car anymore after I try a new distributor I will be done and need a guy in the chicagoland area. So who is the best I will travel a little but nothing over an hour drive. I live basically downtown chicago. Here is the problem any Chicago land mechanic on here want to give it a shot let me know problem
Here are the last thing tried not listed on the post. Code reader will not connect at all. The check engine light is now off ( map sensor not plugged in). did not change ecu relay but check to see if it was warm at all and it is not. Voltage going into both wires at the coil and voltage coming out of the coil wire to dis. No spark from the coil. after shut off the starter does crank. The cats are slightly glowing red. any questions please ask. thank you for the help
