I Dont Get Custom Cam Idea
  • Thread starter Thread starter 89llx
  • Start date Start date May 3, 2015
  • 3
First Prev 2 of 3 Next Last
D
Dave2000GT
229
26
39
Seattle
May 4, 2015
#21
  • May 4, 2015
  • #21
To add to that - the stock 5.0 HO cam is great and should rarely be messed with
Onefine88
Previously 89SSC18
1,422
796
154
May 5, 2015
#22
  • May 5, 2015
  • #22
Hey. I can agree with that. My SSC made 440 to the tires with the stock cam. Drive-ability was perfect.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
May 5, 2015
#23
  • May 5, 2015
  • #23
Gearbanger 101 said:
As would I. I think far too many on this site are unable to see that there's a difference between an OTS cam and a "poorly selected" OTS cam.
It's like the guy who goes out and buys an X303 because it's the raunchiest, most aggressive camshaft that Ford sells and stuffs it into a stock short block, only to find out his car now runs like crap and get's beat all the time? Instead of properly researching all of the offerings by different manufacturers available out there (and there are literally hundreds of them folks), picking one best suited to his needs like he should have, he went with the "bigger is better" approach and ended up with a dud.
Instead of learning the craft and putting the time and effort into understand camshaft dynamics and how they work in relation to the rest of his engine components, in order to correct his mistake....he's sour on pre selected camshaft profiles altogether and decides that the only way to remedy his mistake, would be to go the "custom route".
Quite frankly, I think the term is being thrown around out of laziness more than anything else. It's much easier on ones pride to say "I went with a custom grind, because off the shelf cams are no good", than it is to say "I really just don't know what I'm doing when it comes to picking a camshaft and am gonna let someone else do it for me". After all, the term "custom cam" just rolls right off the tongue when naming off the laundry list of ones parts to your buddies on the internet, right? If nothing else, it makes your car sound far more brag worthy and makes you feel and sound like you've really got something special under the hood.
I guess what I'm saying is that custom cams have their place in more radical, off the wall, or high horsepower combinations....but I'll bet 90% of the owners of cars on the forum probably wont notice a lick of difference between a properly selected OTS cam and a fancy custom one. IMO, many are just going to vote for the one they're told is custom regardless of how it performs, simply out of recognition of the term.
You think you could pick a cam as good as the cam designers could?
CarMichael Angelo
8,909
234
Birmingham, al
May 5, 2015
#24
  • May 5, 2015
  • #24
Yeah,....leave it to me to rain on the benefits of the custom cam.
I maintain that unless you have an "extreme case" is in the example listed by @84Ttop , the "custom cam" already exists and is just waiting on your order.
There is no magic combo left that hasn't been properly targeted by any cam mfg as long as all of the engine parameters fall into what anybody could buy to build that engine "off the shelf". How much extra voodoo can some cam tech guy put into a grind for a 347 w/ 205 heads, streetable compression, a 5 speed, w/ 3.73's, and a small wheezer force feeding air into the thing that hasn't been done already?
I'll bet all of the cam MFG's have a bell that the tech that gets the "custom call" gets to ring ala Boiler room.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
May 5, 2015
#25
  • May 5, 2015
  • #25
I've got a whole bag of Voodoo I sprinkle it in the valve covers and let it soak through the whole motor... It keeps things going in there. Way better than Marvel Mystery Oil could hope to every be
CarMichael Angelo
8,909
234
Birmingham, al
May 5, 2015
#26
  • May 5, 2015
  • #26
I don't doubt that you do.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
May 5, 2015
#27
  • May 5, 2015
  • #27
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 5, 2015
#28
  • May 5, 2015
  • #28
I'm quite certain I didn't say that anywhere?
What I'm saying is that there are enough off the shelf grinds available for the oodles of "cookie cutter combos" out there, that for most, employing the skills of a custom cam designer isn't at all necessary, or beneficial.
The "custom cam" option seem to be the B303 of the new generation. It's trendy and popular to have one and nobody takes you seriously until you do.
Reactions: Dave2000GT
2000xp8
SN Certified Technician
Aug 8, 2003
8,058
1,643
194
NJ
May 5, 2015
#29
  • May 5, 2015
  • #29
rbohm said:
E303 cam specs are readily available, in fact ALL the ford cam specs are available, check this out;
SMALL BLOCK V-8 HYDRAULIC ROLLER TAPPET CAMSHAFTS | Part Details for M-6250-E303 | Ford Performance Racing Parts
scroll down until you get to the specs and find the E303 cam.
and by the way, every cam manufacturer lists the specs for the cams they sell.
wrong again. while some manufacturers will charge extra for a custom grind, as i recall comp cams charges $100 extra, there are cam grinders that will NOT charge extra for a custom grind, clay smith comes to mind.
Let me clarify a bit, i'm well aware of the E cam specs, I know they are around, I was using the E as an example of a cam that has a part number and the specs are known.
I'll bet there is a custom cam out there with the E specs but you wouldn't have to pay the custom price, because you know the E has the same specs.
Not so simple with other spec'd cams. Custom doesn't necessarily mean one off. Cam guys use them all the time, but they keep the part numbers to themselves so the make some money off their knowledge (nothing wrong with that).
I've had customs at $400 and customs at $300. Where is comes from matters for price.
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
May 5, 2015
#30
  • May 5, 2015
  • #30
I understand what everyone is saying about proper cam selection vs "custom cam" advise. I also believe that most people do not know how to select said "proper cam". I know that my personal combo (205 11r heads on a stock shortblock) was a semi unique situation. Yes I could have personally selected a catalogue profile and had descent results. I even talked with representatives from Bullet cams,Comp cams,and Lunati cams. I cross referenced recommendations with offered profiles. I eventually went with a one off design by Brian Friedentag(Freezy) cut by Bullet cams.
Reactions: 84Ttop and liljoe07
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
May 5, 2015
#31
  • May 5, 2015
  • #31
Noobz347 said:
Nearly impossible test to run. Someone who knows cam design very well can pick an OTS cam that's going to be very close to one he might design.
If that portion is true, it's going to reduce the margin of improvement for the custom cut pieces.
I still maintain that custom cams in many circumstances is as much about selection as it is about cutting a one-off.
Sure you can. Take an engine, run an OTS cam. Take the same engine, run the custom cam. Compare dyno #'s.
Reactions: RangerJoe
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
May 5, 2015
#32
  • May 5, 2015
  • #32
I wasn't saying you were. I don't think I could. Majority of the price difference is paying for experience and knowledge. Much like the people that pay an HVAC company to diagnose an issue. There isn't much money to be made on the core itself since most of one man cam guys don't buy them in bulk. Most guys get overwhelmed by all the cam choices available, so they choose to custom route to get the best chance of not picking a turd of a cam. Even guys like Buddy Rawls will tell you that he often times picks OTS cams if they fit the bill. But I would guess you would still pay more since he spent the time to go over the combo and decide that it was the best choice for you. So for most guys its not just to fit in with the custom crowd, but to ensure they get good results for the money they have spent.
Reactions: 7991LXnSHO
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 5, 2015
#33
  • May 5, 2015
  • #33
When I was going to build my 5.0 One of the well respected Cam guru's told me to buy an OTS that was going to be as good as a custom grind.
In the end knowing how it all works and good math skills is all you need, however just like anything else sometimes its better to let the pros decide for you.
Admin Dude
Jan 4, 1985
43,363
21,569
234
Box behind Walmart
May 5, 2015
#34
  • May 5, 2015
  • #34
But where does the OTS cam come from? Is it selected by the same guy who is also going to cut the one-off cam or is it Joe Schmo shade tree mechanic?
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
May 5, 2015
#35
  • May 5, 2015
  • #35
I think he is proposing that the best choice ots be used, then a cam designer try to one up it with something better.
I like the idea, I think it would make the cam designers really step up and shown their worth. I went custom because everyone cried it, and I was afraid that if I didn't, I would be leaving power on the table. My experience (customer service) with my custom cam designer was not worth the $$$ in my opinion. But I will say that the cam preforms well and the specs are a little odd compared to any ots i've seen.
I could have easily chosen a cam based on manufacturer's descrpitions, but i wouldn't truly know how it would perform until after I installed it. I am putting a lot of faith into the designer to say that it couldn't get any better.
Joe
7991LXnSHO
wanna catch the space herp
7,387
2,745
194
Kearney, NE
May 5, 2015
#36
  • May 5, 2015
  • #36
One BIG benefit of a well selected OTS design is it has most likely been run before. That means, especially on a flat tappet design, there is a better chance of the lobes not going flat with your motor as the test pig. On a roller cam, they have already run it to get a better idea of what springs to run without valve bounce.
Bullitt347
I have been doing it wrong this whole time
4,013
3,000
204
Middle of Maine
May 5, 2015
#37
  • May 5, 2015
  • #37
Sometimes a custom cam is about lobe profile instead of lift/duration numbers. You can have two different cams with the same lift/duration #'s but they perform completely differently because of lobe profiles.
My machinist came up with a custom cam for my race motor. Comp Cams did the grind. And truth be told, they took a particular intake lobe profile that they had on record and used a particular exhaust profile that was "in stock" and matched them up to be the cam that was right for my application. They also set the intake centerline and LSA for my app. Was there a part # in the system for my cam, nope, but all of the other information was readily available to "build" my camshaft.
Reactions: 84Ttop
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
May 5, 2015
#38
  • May 5, 2015
  • #38
I would hope the prospective engine builder would do some research- heck even call one of the tech lines at Summit, Crane, etc. or jump on a message board. Even if he used one fhte tried and true cams say a TFS, Anderson or Crane OTS cam and then get the custom cam and see what difference it would make.. We're talking about your average build= nothing exotic- like a stock bottom 302 with a new TFS, AFR, or Edelbrock top end. The same buiild thats been done 10000 times. Even a 347 with a decent set of heads.
rbohm
6,698
550
204
tucson,az
May 5, 2015
#39
  • May 5, 2015
  • #39
in the end, OTS cams are fine for most people, as long as they are particular in their selection. there are times when a good custom grind though is the better way to go.
RangerJoe
2,560
1,146
184
Georgia
May 5, 2015
#40
  • May 5, 2015
  • #40
I know my 331 with AFR 185's and systemax intake has been done 1000's of times. I'm sure the cam grinder spent all of 10 minutes picking out my $400+ cam.
Joe
Reactions: mikestang63
  • 3
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
