I've been fighting that inner demon the past month or so since my ex-girlfriend/current roommate decided she's gonna up and leave in February, meaning I'll have all the bills to myself and no longer have the luxury of borrowing her '90 Lincoln Town Car (which used to be mine) when I need to do some fixin' or upgrades to the 'Stang. True, I'll have another extra parking space available in the driveway when she leaves, and I was sooooooo very close to being 100% convinced that I was gonna sell the 'Stang and buy the Lincoln back from her for my DD. Thing is, being a man has its advantages, and one major advantage is that, such as in this case, common-sense logic tends to be the better decision-maker.
My "inner chick" - y'know, that emotion-driven, whimsical side present in every man's ego, no matter how much they try to deny it - was screaming that I should buy the Lincoln back because: 1. It rides much nicer, 2. Driving an auto is WAY easier to live with in downtown Phoenix rush-hour traffic, 3. The gas mileage is almost the same, 4. It has the same identical stereo setup as the 'Stang but sounds 10x better, 5. The heater works.
Those might sound like semi-logical arguments, but when you consider that this or the 'Stang would be my one-and-only DD, the other arguments come into play with much more weight: 1. I have a spare part on hand for every single electrical doohickey underhood stored in my trunk, so (aside from catastrophic engine failure) I'll never be left hangin' on a roadside, 2. Lincoln digital dashes SUCK, 3. An extra 2-3 MPG average equates to a lot of saved money when you drive as many miles as I do (350+ a week), 4. Tiny parking spaces at work are much easier to handle with a car 1/2 the size of a Lincoln, 5. Extra horsepower has gotten me out of tight spots more than a few times, 6. Removable sunroof and scissor-design window mechanisms are better than a solid roof and crappy cable-and-plastic window regulators (2 of 4 are broken on the Lincoln), and no airflow + no A/C + Arizona heat = DEATH, 7. If a T-5 takes a dump, it's cheap and I can replace it in my driveway, whereas an AOD weighs/costs a ton and usually can't be forced to limp home when it pukes, 8. I've just about got the car to 100% where I want it, so to sell it and buy the Lincoln would basically mean I'd have to start all over again with maintenance and upgrades ... which I am soooooo not gonna have money to deal with next year.
As the case may apply to you in your Mustang versus import debate, even though you've already ditched the Fox, here's some reasons you should consider scoring another 5.0 (or at least a four-banger 'Stanger):
1. The average stock T-5'ed 5.0L will net around 25 MPG highway (if driven sanely).
2. A 5.0 is every bit as reliable as any equivalent year Nissan, Toyota, or Honda, but is actually far less likely to get stolen/broken into - ever notice that imports always top the list of most-stolen autos? And when it does come time to replace major components such as a starter or alternator, 5.0 parts literally cost HALF that of an import, and are in-stock at most places all of the time. (That, and you actually have choices of more than one brand.)
3. There's hardly a single part on a Mustang that you can't somehow upgrade/modify/customize or otherwise replace as necessary/desired; imports are generally limited to stupid cosmetic things like shift knobs, wings, lights, fart cans, and anything else marketed by APC.
4. A FWD car is nothing but a huge headache to work on, as you've usually got 3" or less between the motor and the frame to put your hands/tools into, and most import RWD's are hardly any better. (You can literally stand inside the open engine bay of a 2.3 Mustang, however.)
5. Three words: TIMING BELTS SUCK. Although I think a 2.3L uses a timing belt, the 5.0 has a timing CHAIN that will easily last well over the 100k mile mark, and isn't prone to randomly breaking/slipping and thereby causing disastrous piston-to-valve contact under normal driving conditions. (I don't consider revving beyond 3500 RPM's to be "normal" driving, though.)
6. Torque is a beautiful thing to have, indeed.
7. That wagerline.com ad to the right of this Quick Reply box with the two hot cheerleaders is distracting the heck out of me.
8. There isn't a four-cylinder ANYTHING on earth (excluding motorcycles) that doesn't sound like a pissed-off bumble bee when it's being run at WOT, which is just silly.
9. I like to pad my lists to come out to 10 sometimes for no reason, at all.
10. Once you've owned and truly come to love a Mustang of almost any year, you WILL hate yourself eternally for selling it, and you WILL continue to kick yourself in the arse until you finally break down and buy one again.
If you're looking at cars in the $5k range, you can actually score a decent early SN95 ('94-'95 models, usually) for just a couple hundred bucks under that mark - a lot more comfy, more modern looks (chicks dig all that weirdness), and fewer years of age = fewer squeaks n' rattles and little things to fix from time to time.
There. Now, after having typed out that small novel, I shall go dunk my fingers in ice for a few minutes and then type the rest of my e-mails with my toes.
