95yellowGTS
The vent tube is actually inside the bigger filler tube. (at least it was on every other Ford I've owned) What happens is when you put gas in the tank, the amount you pump in displaces the same amount of air that's in the tank....and if that air has no where to go (vent tube)....it pressurizes the tank and is forced up the filler tube (sprays gas on ya..) Fix the vent tube and you should have no problem filling up! That doesn't mean just leave the tube out, it has to be in there to work properly.
