I hate my T45
tjm73
2,418
Rush, NY
The T45 in my '98 GT seems to be acting up a lot lately. My car has 75,000 miles on it and it's a total daily driver. It's almost 100% stock. The only mods I have are a UPR shifter, clutch quad kit and Magna Flow catback.
For the last year or so it's acted up once and while, but lately it's been acting up all the time. When I put the car in reverse, 80%-90% of the time it pops out of reverse (annoying and embarresing). It also often grinds going into 3rd under acceleration. It does it under hard or light acceleration. And it also sometimes does it on deceleration.
Now 1st, 2nd, 4th and 5th are fine and never give me any trouble. So I'm starting to wonder if I'm seeing the signs of a bad synchro. I think that 3rd and reverse share a synchro, but I'm not sure.
I double checked my "over shift"/stop bolt clearences on my shifter and they are ok. This problem existed (all be it not as often) long before the shifter upgrade.
Anyone else ever experience something like this or know what might cause such troubles?
Yeah mine grinds going into second if im getting into it but it could be the rush im in or sumthing.Enyone here have a t-45 rebuilt if so how much cause i seen in mm-ff theirs a place for under a thousand you get a new trany or could go for the 2400 t56 swap.
when I bought my car I knew the t-45 had paper synchros which is why i treated it good and it still works great, the only time mine popped out of reverse was when I had my shifter improperly adjusted
Check your clutch fork! I had a problem with mine grinding third gear, and popping out of reverse. It wouldnt feel like it wanted to go in and then you'd think it was in after trying to put it into gear a few times and you'd let the clutch out and then you'd hear an extremely loud grind, always happens when hot girls are around lol. It never felt like it wanted to go into gear or anything. Come to find out my clutch fork was about to fall off the pivot. Its about 35 bucks for a new clutch fork through randy of modulardepot.com. Well worth the money if you ask me. I haven't had a problem with it popping out of reverse or any shifting issues really. Good luck!
Thanks for the tip I'll check it out. That'd be nice if it was that easy of a fix. Cheaper than a rebuild too. :nice:
How hard is it to get to the shift fork ? I would love to be able to replace mine to take care of similar problems as everyone else..does the tranny need to be dropped and taken apart or what?
the t45s are junk i tore mine up when it acted up and now every gear is first gear(even neutral). forget rebuilding just get a tko500/600. i have a 600 and love everything about it. well almost everything. 5th gear is kinda loud. :nonono:
yeah my T-45 is a piece of crap too. i cant do quick 1-2 shifts most of the time or else is grinds. oh btw, the syncros are made of carbon fiber i believe, not paper... you're thinking of the blocker rings. Also, reverse is unsyncronized, which is why its usually so hard to get into and grinds occasionally. im looking at a rebuild myself, i was considering a T-56 but the first gear (2.97:1) is too steep for a basically stock motor, compared to the T-45 (3.37:1). Plus it costs more than a rebuild
